Noise from right rear. Please Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by walthouston7, Nov 27, 2011.
  1. Nov 27, 2011 at 10:44 PM
    walthouston7
    walthouston7 [OP] Member
    Walt
    Memphis, TN
    2005 Tacoma Prerunner Sport
    Cold air intake, 22's are gone (thank god) got 17's and BFG's, Audio system, Flowmaster 40
    2 days ago my 2005 107,000mi Tacoma started making loud banging noises when I hit bumps. At first it sounds like the exhaust pipe but I pretty much ruled that out. Its not my hitch either. It bangs on the "up" and "down" of hitting a bump. Like something is in suspension that is banging on two objects top and bottom. I researched so in the morning I will check the shock bushings and give the leaf a closer inspection. I can't afford to pay the dealership. Please help!
  2. Nov 27, 2011 at 11:24 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Are the U bolts holding the spring pack tight? Are you sure one of the exhaust brackets has not come loose & maybe the pipe is moving around?
  3. Nov 27, 2011 at 11:25 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Loose spare in the carrier ?
  4. Nov 27, 2011 at 11:26 PM
    Warputer
    2011 TRD Off Road
    Oh yeah...good one Oz! :cool:
  5. Nov 27, 2011 at 11:27 PM
    OZ-T
    Peter North
    British Columbia
    Had it happen to me on my old truck , took me forever to figure it out .
    Duh
  6. Nov 28, 2011 at 12:06 AM
    walthouston7
    Walt
    Memphis, TN
    Wow. Thanks for the quick advice! I checked the spare and it's solid. It would make sense that a bracket for the exhaust would be an issue since I just had a new muffler put on but Ive shaken the shit outta it with no noise. Also, you would think since hitting bumps makes the noise that I could duplicate it by jumping on/shaking the truck but I can't. This noise seems to come very easily on small bumps even at low speeds. I'll check the u bolts in the morn.
    Again, i really appreciate any advice. It's 2am and I'm stressing it so much I can't sleep. Fml
  7. Nov 28, 2011 at 10:51 PM
    walthouston7
    Walt
    Memphis, TN
    I finally found out what it was! I got my wife to go back and forth over a speed bump and noticed that one of my leaf springs had a broken leaf! It just snapped in the middle. Ive never even heard of that. I have over loaded my trailer (that I haul alot) a few times and I bet it couldnt keep up. Thanks guys!
  8. Nov 29, 2011 at 12:27 AM
    Warputer
    2011 TRD Off Road
    Glad U got it figured out! :cool:
