noise in rear end
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RLMoody, Feb 7, 2018.
  1. Feb 7, 2018 at 4:38 PM
    RLMoody
    RLMoody [OP] Well-Known Member
    2017 Toyota Tacoma SR
    Recently I started to smell gear oil when I parked my truck at work. I dismissed it as being someone else car leaking in the parking lot. Today while driving to work in the fresh fallen snow I heard a loud noise when my tires broke traction several times. Thinking the worst I called the dealership and they are taking my truck in tomorrow to see what is going on. I dont see any oil leaks and the driveway has no stains from a leak. I was at a loss as to what the noise was.
    I did not mention that I am hearing impaired.
    This evening I took the truck back out in the snow and spun the tires and realized what I think I am hearing is snow hitting the the plastic bed and fender liners. Duh! With all that plastic back there it does not sound like snow hitting metal like my other cars did under the same circumstances. And my hearing is bad on top of it.
    I am still taking it in to the shop tomorrow because its time for its service check anyway and also will let them rule out any problems. It did pass the rear end recall 6 months ago.
    Im just curious if anyone else has noticed how noisy the plastic beds are in these Tacoma's?
    It sucks when I can hear things I shouldn't and not the things I need to.
  2. Feb 7, 2018 at 5:48 PM
    Fett85
    Fett85 Well-Known Member
    Ohio
    2021 Tacoma TRD Off Road 4x4
    I have bad hearing as well (ear infections as a kid, metal band for several years and guns). The road noise I get varies a lot based on weather and road conditions, plus I have had rattles I think (knocks on wood) have solved
  3. Feb 7, 2018 at 5:56 PM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    You are hearing the abs pump and traction control working. Look at your dash...youll see a flashing traction control light. The ABS pump is very loud
    2016Tacoman likes this.
  4. Feb 7, 2018 at 5:58 PM
    pjensen641
    Boone, IA
    You can verify this by deliberately slamming on the brakes in the snow (at a safe speed). You should hear a similar noise
    2016Tacoman and shakerhood like this.
  5. Feb 7, 2018 at 6:05 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    In reference to the smell of gear oil...are you plowing the rear end through snow?
  6. Feb 7, 2018 at 7:47 PM
    Cole man
    Cole man I like a clean taco....
    Paul
    Bluegrass state
    2017 tacoma SR 4x4 V6 MGM
    Stock so far
    Its never good to have noise in your rear end :rasta:
  7. Feb 8, 2018 at 4:18 PM
    RLMoody
    What pjenson641 said is interesting. The noise startled me and I had no idea what it was. I will pay more attention the next time and watch my dash when it happens. I have driven the truck in the snow previously and did not hear any noise but then again I never lost traction. As for the gear oil smell the dealership ruled out any leaks today but did not offer any explanations either. Just said everything is OK. Im back to thinking it was someone else car parked beside my truck I was smelling.
    When you have a hearing loss you can still hear things but they sound different to me than they would to you. I liked Fett85 comments as well. My hearing loss came from working under a trim system that sounded like a jet engine in the printing plant I worked at for 19 years. Judas Priest, Metallica and Avenged Sevenfold didnt help any either.
    Fett85 likes this.
