Noise in the dash
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperr, Feb 8, 2016.
  1. Feb 8, 2016 at 12:45 PM
    Trapperr
    Trapperr [OP] Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    So I've noticed a strange sound coming from my vents. It sounds like something in there is trying to self adjust. It sounds like a cd player trying to read a burned cd. Like it's trying to "focus" or something. I can hear it with the air off mainly. any ideas?
  2. Feb 10, 2016 at 8:23 AM
    AFlynn
    AFlynn Member
    Orange County
    2002 Silver Tacoma SR5 4x4
    Icon 2.5 Ext travel coilovers, Icon uniball UCA's, Icon rear shocks, OME Dakar Leaf Pack, American Racing ATX rims, Hankook Dynapro 265/75/R16, SnugTop Shell, Carpet kit, Blue LED Interior swap, debadged
    I dont know if this is the similar noise you're talking about, but from time to time I'll hear a whining or like some sort of higher pitched vibration ? I haven't heard it in a while though
  3. Feb 10, 2016 at 8:34 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Post a video with the noise
  4. Feb 10, 2016 at 10:32 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    My dash sounds like there are 2 mice violently fucking inside. It's kinda hot so I've haven't looking into fixing it.
    I think this is actually a common problem, hopefully someone else can chime in, I don't have much information myself.
  5. Feb 10, 2016 at 11:23 AM
    Trapperr
    Reno, NV
    I get that mouse fucking noise too! interested to hear what you find out
  6. Feb 10, 2016 at 1:11 PM
    LocknLoad
    LocknLoad Well-Known Member
    near the Cherohala Skyway, TN
    2015 DC Off-Road 4x4
    With a first gen - I'd be surprised if you DIDN'T have noises coming from your dash. Mine seem to change with the seasons :)
    DustStorm4x4 likes this.
  7. Feb 10, 2016 at 3:25 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    @Trapperr
    I think the noise has something to do with the climate control thermostat which opens and closes the fresh air intake door. Mine makes the same noise if the both the weather is mild AND the thermostat is turned all the way to cold. I think what is happening is that the high and low trigger temperature overlap or are too close together causing short cycle of the fresh air intake.
    The workaround is that if you turn the thermostat one click toward warm the noise goes away. I'm not sure of a permanent fix. I've seen it discussed on the forum in the past.
  8. Feb 10, 2016 at 3:27 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I've seen pictures of mouse carcasses on the cabin air filter, could there be a connection?
  9. Feb 10, 2016 at 9:28 PM
    Trapperr
    Reno, NV
    My truck has a cabin air filter?
  10. Feb 10, 2016 at 9:29 PM
    Trapperr
    Reno, NV
    Good call. My control knob is always set to heat when I hear it. I'll try a little towards cold when I hear it next time i drive.
  11. Feb 10, 2016 at 9:33 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    remove your fan. it's 3 bolts under your glove box. see if anything fell into it.
    check out your blend door and/or motor. they may be malfunctioning.
    thats all that can come from the vents. good luck!
  12. Feb 10, 2016 at 9:49 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    LoL. I just noticed you were in Reno. That makes sense. I think the thermostat gets confused when the outside temperature is very close to the knob temperature. For me it happens at the colder setting. For you at the hotter setting.
  13. Feb 11, 2016 at 10:33 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I know what you're talking about, there is a small module underneath the dash. Stick your head up under the passenger side floorboard and look towards the area behind your ash tray. You'll see a metal track looking thing clicking and moving. Not sure what it does or how to fix it. Mine does this too sometimes.
  14. Feb 11, 2016 at 2:45 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
  15. Feb 11, 2016 at 5:38 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    mine sounds like Chris Farley dropped a bag of Peanut M&Ms down the vent...
    Mscott2 likes this.
  16. Feb 12, 2016 at 8:17 AM
    Madjik_Man
    Colorado Front Range
    My rodent orgy sound was my blower motor on the HVAC.
    Very common.
  17. Feb 12, 2016 at 12:00 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Even if I'm hearing it with the fan off?
  18. Feb 12, 2016 at 12:06 PM
    wilcam47
    Will
    Bourbon state
    check your hood prop clip..it can also sound like its coming from the dash but isnt
  19. Feb 12, 2016 at 12:07 PM
    Madjik_Man
    Then that's a no.
    Sorry if it was mentioned before, I was on my phone which sucks reading from.
  20. Feb 12, 2016 at 12:45 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
