noise in transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fasttalker372, May 14, 2009.
  1. May 14, 2009 at 4:33 PM
    fasttalker372
    fasttalker372 [OP] Member
    macungie, pa
    05 biscaine
    Hi all,
    I have a 2005 2WD base taco 2.7 5speed and have a funny noise. at startup, it's fine. After it warms up, the truck sounds like a deisel when it's ideling. At first, I thought it was lifter noise or something in the engine. However, I've discovered that if I push in the clutch, the noise goes away. It's been doing it for a while, but I think it's getting louder.
    Do you think it's the clutch or something in the trans? Does anyone else experience this?
    thanks,
    chet:confused:
  2. May 14, 2009 at 6:51 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
    id say its your throw out bearing..IMHO
  3. May 14, 2009 at 7:37 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Check your clutch or like he said^^ you throw out bearing
  4. May 15, 2009 at 5:10 AM
    hans2
    hans2 Member
    2009 Base 4-cyl 5-spd. Same noise but only when the AC compressor is engaged (corresponding to a specific idle speed). No noise at other idle speeds or with clutch pedal in. Only 2,500 miles too. :(
  5. May 15, 2009 at 6:06 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Dood- Take it to the dealer. You are still under warranty...If you are worried about it- don't pout- Get them to look at it.
  6. May 15, 2009 at 8:33 AM
    hans2
    hans2 Member
    No doubt I can easily take it there. But I predict I'll get the "they all do that" runaround. Will wait until it gets worse.
  7. May 15, 2009 at 10:09 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    To the original poster.... probably the throw out bearing as said. I'm not sure on these trucks but most other cars I had I just ignored it as it's really not that big of a deal and would wait until the clutch gives out completely.
    For the '09.. take it in... you have nothing to lose and it's documented early there was an issue from the start. That way even if they don't do anything, you'll have ammo for later if it becomes more drastic.
  8. May 15, 2009 at 4:00 PM
    fasttalker372
    macungie, pa
    05 biscaine
    thanks everyone,
    It has 85,000 miles on it, so it probably won't be too much longer before it needs a clutch. As long as it safe to drive, I can put up with some noise. I'll just turn the stereo up.
