Noise that increases with car speed...ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MadMedic35, Mar 14, 2019.
  1. Mar 14, 2019 at 9:41 AM
    MadMedic35
    MadMedic35 [OP] Well-Known Member
    Sandhills, NC
    09 TRD SPORT DCSB
    Fox 2.5 coilover, TC UCA, FOX 2.5 res rear shock, OME leaf pack, SCS Ray-10 gold, Nitto Ridge Grappler, SoftTopper. On order: Relentless Fab Summit Bumper, HC rear bumper with tire carrier, sPOD, Powertray,
    I have a 09 DBL Cab Sport with 130k on it. Fox 2.5 suspension and 33" Nittos. Replaced wheel bearings around 75k and CV's around the same time and a needle bearing once years ago. About 2 weeks ago noticed a noise that speeds up with car speed and is only constant when turning to the right. Its not a typical growl of a bearing...more tinny sounding like a coke can in a bike spoke. Assumed it was a bearing so I replaced the passenger side wheel bearing (went with Jersey Built in spite of all the negative and had no issues getting the part). Passenger side CV has some play but not bad. Drivers side bearing and CV sound and feel fine. U joints have some grease spray so thinking of replacing those. Any other ideas?
    Edit to add that no change from 2 to 4H
  2. Mar 14, 2019 at 6:16 PM
    MadMedic35
    Sandhills, NC
    09 TRD SPORT DCSB
    So this is now a full on shit show. Decided to do the U joints. Watched all the videos, got all the parts and tools from O'reillys. Pressing in the joint at the yoke flange and didn't realize a needle had fallen. Commence to cranking the press and hear a snap and see the opposite clip had shot out and taken enough of the flange with it that a clip won't retain. Now have to wait on a new flange yoke from Northern Drive Train. All for some annoying noise...
    desertrunner24 likes this.
  3. Mar 14, 2019 at 6:29 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    :annoyed: probably should have the drive shaft balanced as well
  4. Mar 15, 2019 at 9:41 AM
    MadMedic35
    Sandhills, NC
    09 TRD SPORT DCSB
    Ordered a new flange from Northern Drivetrain. Should be here tomorrow. Gives me a day to be productive around the house
  5. Mar 16, 2019 at 11:28 AM
    96carboard
    96carboard Well-Known Member
    My recommendations are as follows;
    1) Don't buy and replace parts until you actually figure out what part is causing problems.
    2) Sounds like you probably should find someone to give you a hand with this job.
  6. Mar 16, 2019 at 5:22 PM
    MadMedic35
    Sandhills, NC
    09 TRD SPORT DCSB
    Yes to the first and no to the second. Flange arrived today and it’s a match. Tomorrow I’ll get the driveshaft put back together tomorrow
  7. Mar 18, 2019 at 4:18 AM
    96carboard
    Well then... have fun o_O
  8. Mar 18, 2019 at 5:22 AM
    MadMedic35
    Sandhills, NC
    09 TRD SPORT DCSB
    Final update:got everything back together yesterday. Took it out for a spin and the noise was way louder. Back in the garage and climb under it. Finally notice the gas tank heat shield is bent out. I bent it back into place and go back out driving. No noises at all. No vibrations up to 60. Long story short: I’m stupid and don’t just start swapping parts until you really see what’s wrong
  9. Mar 18, 2019 at 5:35 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Good lesson.... sadly, it’s easier said than done trying to be patient with our trucks. We all want to “fix” something if there’s a problem
  10. Mar 18, 2019 at 5:47 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Always suspect a heat shield or other type of sheet metal part first when you hear “tinny” things...
    Congrats on the fix, new u-joints, yoke & bearing. Should be all set for awhile with those parts.
    You might want to consider adding “Solved” to your thread title. Helps others with searching for similar issues.
