Noise under Glove box
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco Phil, Jul 4, 2024.
  1. Jul 4, 2024 at 3:46 PM
    Taco Phil
    Taco Phil [OP] Taco Phil
    Galveston, Texas
    04 2.7 3RZFE Reg Cab 4X4
    Beautifully stock
    Noise and vibration is coming from the picture area. I don’t have a cabin air filter in my 04, but it’s below where the cabin air filter would have been. Any thoughts? Sounds like something small is struggling to run.
    thanks for your time.
  2. Jul 4, 2024 at 8:12 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    None of us have cabin air filters in our 1st gens, unfortunately. Do you have heat/AC? (I think everyone has heat, so the answer is probably yes.) Assuming you do, the area under the glove box is where the fan blower motor/box. That's pretty easy to remove - just two screws for the glove box (which might even be optional but gives you more access) and then three screws for the blower motor.
    Here's my blower motor, unscrewed but still hanging via the power harness. could be that you have leaves (or something) in there that are making noise as it spins.
  3. Jul 5, 2024 at 5:10 AM
    Taco Phil
    Galveston, Texas
    Beautifully stock
    thanks for the reply Yes, I have AC. But I hear that noise even without the fan turned on. Picture I posted looks like a big black plastic cover, but in fact it’s pretty small, maybe 4 x 4 inches. That’s where I felt vibration/noise. Should it make noise without the fan switch on? And it’s sporadic. It’s not consistent.
  4. Jul 5, 2024 at 5:14 AM
    Clearwater Bill
    Billy
    Largo Florida
    If this happens with the truck off, you may have a mouse house happening
  5. Jul 5, 2024 at 5:19 AM
    Taco Phil
    Galveston, Texas
    Beautifully stock
    I only hear the noise when the truck is running. But the fan switch is off. I could put my hand on it and feel the noise and vibration.
    wilcam47 likes this.
  6. Jul 5, 2024 at 8:38 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Likely one of the blend door actuators is struggling. To help diagnose, when you're hearing the sound, switch your hvac controls all the way to heat, and then all the way to cold. If the sound goes away then it's the hot/cold blend door. If that isn't it, you can switch on and off the air recirculate, if that changes/eliminates the sound then you're likely dealing with the fresh air blend door actuator. There are some aftermarket replacement door actuators for sale on Rockauto for like $30 if that ends up being your issue.
    CD20H and Taco Phil[QUOTED][OP] like this.
  7. Jul 5, 2024 at 9:00 AM
    Taco Phil
    Galveston, Texas
    Beautifully stock
    Thank you. Totally sounds like what it could be. Appreciate your insight.
  8. Jul 19, 2024 at 5:24 PM
    Taco Phil
    Galveston, Texas
    Beautifully stock
    You were correct. Thank you.
    The noise went away when I turned the HVAC controls to hot and then cold. Then I pushed the fresh air/recirculate button on and heard noise, so I turned off, and the sound hasn’t returned.
    So fresh air intake door is always open now. Even with the AC on. I know I’m gonna wanna close when winter comes.
    It seems to be the actual air recirculate button but I could be wrong it could be just the door not the actuator. I learned a lot thinking about this. Thank you.
  9. Jul 19, 2024 at 5:35 PM
    Williston
    Williston Unknown Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    FWIW: The fresh air intake is the normal mode of operation, even in the winter. The heater core and system can deal with ice-cold air coming in during the winter. You probably would not want to defeat this to go with/select recirculated air only. In many scenarios you'll end up with interior fogged-up windows with constantly reciruclated inside air, moreso if you have passengers or wet gear and floor trays in the truck.
  10. Jul 19, 2024 at 5:38 PM
    Taco Phil
    Galveston, Texas
    Beautifully stock
    Yes, point well made. I still have the problem though. If I ever want to close it, I have to deal with the noise. What do you think it is?
  11. Jul 19, 2024 at 6:57 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Kaleo
    Glad u survived Beryl
    I got 3 travel trailer estimates to do on Boliver P. on Monday
    It’s a small servo motor that you need
    Think there are 2, maybe three
    I have found which one(like you have done) is needed by touch
    Then go to Toyota microfiche to determine which exact servo you need
    GL
  12. Jul 19, 2024 at 7:16 PM
    Taco Phil
    Galveston, Texas
    Beautifully stock
    thank you, sir! I appreciate the wisdom. Looks like I have another project.
    ControlCar[QUOTED] likes this.
  13. Jul 19, 2024 at 7:58 PM
    ControlCar
    Steven
    Sugar Land TX
    Always Brother.
    thank goodness my old taco has cables(as does my other vehicles)
    read up on the replacement
    I have read tht major parts need to be removed to access servo motors
    IMO
    As long as you can contort you body enough(yoga helps…lol) you can access the door motors
    I.E. I’d rather take out a 4 bolt seat than take out 1/2 the dash any day
