Noise when going in reverse
Discussion in '1st Gen. Tacomas (1995-2004)' started by cuaco72, Nov 1, 2010.
  1. Nov 1, 2010 at 8:30 AM
    cuaco72
    cuaco72 [OP] Member
    Joaquin
    Brownsville, TX
    Fully Stock
    hi guys, need to find out what's wrong in my truck.
    its a 95 taco 4wd 4 cyl 2.7L reg cab.
    My truck makes a kinda loud ticking sound when going in reverse, sounds more like a banging noise, it sounds like its comming from the trany and it only does it in reverse.
    I can feel the banging noise in the steering wheel, its almost as if the u-joint were loose or if the shafts were loose, you know something that's rotating and hitting something as it rotates.
    Does anybody know what the hell this noise is? and have you had it fixed?
    any comments, sugetions will be greatly appreciated...
  2. Nov 1, 2010 at 8:31 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did you check the u-joints?
  3. Nov 1, 2010 at 11:13 AM
    fireman_343
    fireman_343 Ultimate TRD
    Brian
    Columbus, OHIO
    05 TRD Dlb Cab
    Viper Alarm, XD Series Wheels, Pioneer touch screen radio/nav system.
    Sounds like u-joints to me! I'm sure they are over due if never changed before!
  4. Nov 16, 2010 at 10:33 AM
    huskyking
    huskyking Active Member
    Scott
    Ontario, Canada
    03 tacoma SR5 TRD
    I just bought a 2003 and mine makes a noise going into drive or reverse,sort of like a clunk,click noise, determined that it is the slip yoke on drive shaft, i think yours has this...? grease them up every 3k they said, if your noise is same as mine it is characteristic...
