noise when i start truck
Discussion in '4 Cylinder' started by green2010taco, Nov 5, 2010.
  1. Nov 5, 2010 at 10:10 AM
    green2010taco
    green2010taco [OP] Member
    virginia
    2010 tacoma 4x4
    My 2010 5 speed is making a noise when I start it and then it stops. Then I turn truck off and start it again and it doesn't make the noise. Does anyone know what this might be?
  2. Nov 5, 2010 at 10:11 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Gotta be more specific, where's it coming from, is it a knocking noise, etc.
  3. Nov 5, 2010 at 10:12 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Can you be a little more specific on describing the noise? Grinding? Chirping? Whining? Electric Motor type noise?
    When exactly do you hear it? When you put it in gear and start to move? Or immediately upon starting the engine?
  4. Nov 5, 2010 at 10:25 AM
    green2010taco
    virginia
    2010 tacoma 4x4
    It sounds sort of a grinding sound I noticed it a couple days ago. And it only lasts for about a second or to then it stops. But it seems to only do it when it hasn't been started to a while. Becuz the last time it happened as soon as it made the noise I turned the truck off I immediately started it back up and it didn't make the noise.
  5. Nov 5, 2010 at 10:27 AM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    do you have a chance to put it in gear before it makes the noise?
    is your ac on?
  6. Nov 5, 2010 at 10:27 AM
    krimson
    krimson Nothin
    TRD Off Road
    It could be the AC making a clunk. I dunno im just making a guess, if so its completely normal.
  7. Nov 5, 2010 at 10:28 AM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    If the vehicle is in gear and clutch engaged, and you are slowly movin forward, it could be the ABS initializing.
    Can some of you others jump in here with a yea or nay on that?
  8. Nov 5, 2010 at 10:29 AM
    CopDoctor
    Trinidad, CO
    yea, that's why i asked about being in gear, that would be the ABS testing itself...but from the sounds of it, it's happening sooner than that
  9. Nov 5, 2010 at 10:30 AM
    green2010taco
    virginia
    2010 tacoma 4x4
    No. The truck is in nuetral then I push the clutch start button then turn key and as soon az I do that it makes the noise. And I don't have the a/c either.
  10. Nov 5, 2010 at 10:33 AM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    :notsure:
    Take it to the dealer and have them explain it or check it out.
  11. Nov 5, 2010 at 10:34 AM
    green2010taco
    virginia
    2010 tacoma 4x4
    Its not the abs initialising. It does that once I start moving
  12. Nov 5, 2010 at 10:37 AM
    CopDoctor
    Trinidad, CO
    i'm out of ideas. lots of tacomas get a grinding when the ac turns on...but if it's not that nor the abs, then i'd have someone check it out
  13. Nov 5, 2010 at 1:56 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    I sometimes get the same noise. I thought it was the A/C but noticed it does it when the A/C is turned off lately???....Just another bump, creak and grind to learn to live with:)
  14. Nov 5, 2010 at 2:48 PM
    2010whitetaco
    2010whitetaco Well-Known Member
    Gaston
    Fort Worth
    single cab 5-lug
    ReadyLift 2 3/4 front 1 3/4 rear universal armrest Texas Rangers decal 235/75/15 Goodyear Duratracs Kobalt Slim Line Compact Truck Tool Box Secondary air filter removed TOYOTA decal on tailgate
    mine makes the same noise sometimes
  15. Nov 5, 2010 at 2:50 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Remember that if your vent selector is set to defrost then it is the same as the a/c being on in it will run the pump, unless you mod it.
  16. Nov 8, 2010 at 4:09 PM
    green2010taco
    virginia
    2010 tacoma 4x4
    I think the noise was coming from me having the vent selector set on defrost. And I have taken off defrost when truck is off and it is not making the noise now. Thx for the help.
  17. Nov 8, 2010 at 8:20 PM
    CopDoctor
    Trinidad, CO
    defrost = a/c
  18. Nov 13, 2010 at 6:15 PM
    olehipi
    olehipi Active Member
    Pensacola,FL
    taco negro
    Mine makes this noise when the AC is turned on after being parked for a few days. Maybe rusty pulley?? I park mine outside. It can be pretty loud, sounds terrible.
  19. Nov 13, 2010 at 7:16 PM
    michaelahunt
    michaelahunt TacoKid
    Michael
    Tennessee
    10 PreRunner Acess Cab SR5 Magnetic Gray Metallic
    I hear the sme noise in mines, only when I first start it and after it's been sitting awhile. But like some of the replies have stated, I think it's probably the ac/heat vent selector. This is where the noise seems to come from as I listen.
  20. Nov 27, 2010 at 7:35 AM
    OUG13
    OUG13 Active on 3 Forums, with nothing in common.
    Ohio
    2009, Reguler Cab 4 X 4
    Mine after sitting at least two days, makes a "pop & click" out of the exhaust, battery seems weak also at that time. 2009 17,000 miles... but after about 20 seconds, back to normal..(everything turned off on the panel)
