Noise when leaving parked spot in Drive, then again in Reverse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bttrbsch, Jan 18, 2022.
  1. Jan 18, 2022 at 10:34 PM
    bttrbsch
    bttrbsch [OP] Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    Got a clunking noise that I cannot diagnose after reading countless TacomaWorld threads. Wondering if anyone can guess at what it might be....
    When I shift my truck from park to drive and drive forward slowly in a straight line: No noise
    When I shift my truck back to reverse and drive backward slowly in a straight line: No noise
    When I drive around town/highway, both aggressively and reserved: No noise (suspension cycling quickly and slowly).
    When I shift my truck from park to drive and turn slowly as I leave the stopped position: "clunk" noise somewhere in the front of my truck.
    When I shift back to reverse and turn slowly as I begin to travel backward: "clunk" noise somewhere in the front of my truck.
    I can repeat this singular "clunk" by transitioning from drive to reverse and slowly traveling ~10 ft. while turning the steering wheel.
    So long as I stay in either drive or reverse, it will clunk once then not happen again for the rest of the drive. For example, I turn out of a parking spot in a parking lot - the clunk happens. Then I continue my drive the rest of the way home with no noises (including stopping at lights, quick lane changes, etc.).
    In the past month I installed a lift (front and rear), had an alignment done, and installed extended brake lines in the rear (within the past week). The noise just started within the past week.
    Any ideas??
  2. Jan 18, 2022 at 10:41 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Check your lower ball joints
  3. Jan 18, 2022 at 10:44 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Sounds like it could it be brake click? Annoying but “normal” for some Tacomas. How old are your brake pads?
  4. Jan 18, 2022 at 10:48 PM
    bttrbsch
    Michael
    Bellingham, WA
    Ah! This is one component I didn't check this past weekend. I will investigate tomorrow!
    Shadowhunter[QUOTED] likes this.
  5. Jan 18, 2022 at 10:50 PM
    bttrbsch
    Michael
    Bellingham, WA
    I saw a few threads talking about brake click. I replaced the front pads within the last year, and don't think they would randomly start clicking, especially during a slow turn from a stopped position. I'll see if I can check them this week though!
  6. Jan 18, 2022 at 10:54 PM
    GHOST SHIP
    GHOST
    It happens sporadically. I’ve had it happen to my brake pads even when they don’t require immediate changing (about 1/2 worn). I started using a little permatex brake grease (the purple stuff) on the back of the pad and the piston and use two retaining clips for each caliper that seems to have solved the issue. YMMV.
  7. Jan 18, 2022 at 10:56 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    It’s your entire break calliper and the pads shifting. My truck did this since new. It’s gotten worse over time. Replacing pads has no effect.
    33yrsoftoys, AZGOLD, tcjacado and 2 others like this.
  8. Jan 18, 2022 at 11:12 PM
    Stick to your guns
    Stick to your guns Well-Known Member
    Bronson
    Lake Stevens
    2005 Black DCSB TRD off road
    Bilstean 6112, progessive AAL, method NV 17X8.5, Falken wildpeak AT3 285/70R17, Hooke Road rack, Spyder headlights, mesh grille, BAMF hybrid bumper.
    it might be your CV's making noise from the increase in the angle from your lift. check your CV boots for for tears and maybe drop your diff if your lift is more than a couple inches
    GrizzledBastard likes this.
  9. Jan 19, 2022 at 7:41 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    My truck has a similar clunk/noise, and at least on mine its the front pads shifting. I'd also check your cam bolts, as one of those loose will shift the slightest bit/send noise through the cab
    tcjacado likes this.
  10. Jan 19, 2022 at 7:47 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Check torque specs on everything, more specifically lower control arms/cam bolts. Guarantee alignment shop torqued too low; I think the spec is 100 ft/lbs or close to it at least. Mine did the same, was only torqued to around 50 ft/lbs.
    Edit: the above could be your clunk/click, but as others noted, brake pad shift will give a click/clunk and from what I understand its "normal" and we all may be experiencing what you're describing.
    SR-71A and tcjacado like this.
  11. Jan 19, 2022 at 7:55 AM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    how much lift did you do? could be needle bearing. might need ecgs
  12. Jan 19, 2022 at 8:01 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    As others mentioned, Brakes.I had exactly the same problem. I removed brake pads cleaned shims, added brake grease to them, also cleaned pins, greased and noise went away.
    tcjacado and cryptolime like this.
  13. Jan 19, 2022 at 8:08 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I have similar creeks and what not. Imo till something falls out or lights start flashing not worried about it. I off-road frequent and use it like a truck. Don’t worry :rasta:
    33yrsoftoys and tcjacado like this.
  14. Jan 19, 2022 at 10:06 AM
    bttrbsch
    Michael
    Bellingham, WA
    Looks like I have a solid list, appreciate the recommendations everyone! Things I will check in the coming week:
    1. Lower Ball Joints (jack front of truck up, shake the wheel and listen for noise and look for movement. Also pry bar and look for play).
    2. Brake Pads (remove, add grease to back, inspect pins and replace pins if needed).
    3. CV Joints (look for tears)
    4. Cam bolts (should be torqued to 100 ft-lbs)
    5. Evaluate ECGS
    I checked cam bolts last week, but will double check to make sure. I believe ECGS can be felt while driving in a straight line, whereas this is not the case - no "clunk" or noise while driving straight or around town. Only happens at low speed (turning in a parking lot).
    Noise hunting is a pain! Just when I was considering my truck "done" (is it really ever truly "done" though?) and ready for spring adventures this mystery noise pops up.
    I'll keep this thread posted with my findings on the 5 items above.
  15. Jan 19, 2022 at 10:51 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it's your brakes
    na8rboy likes this.
  16. Jan 19, 2022 at 11:07 AM
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    I
    I’m up in Bellingham if you want a little help shaking it down. I’ll probably be gone around 1:00-2:00 this afternoon though
  17. Jan 19, 2022 at 11:18 AM
    bttrbsch
    Michael
    Bellingham, WA
    I would absolutely love the assistance as it’s difficult to locate while in cab, but the truck is getting an oil change (couldn’t pass up on the dealer coupon). I really appreciate the offer though!!
  18. Jan 19, 2022 at 11:21 AM
    Off Topic Guy
    Usually symptoms of the clamshell bushing (ecgs as some people call it, that's just the company that makes the better replacement) would be vibrations at speed. If one had that issue, it can be tested by switching to 4HI at speed, in which the vibes would go away. Doesn't sound like your issue described, but also not a bad idea to replace when lifting as precaution, even though its not always needed. Again, I'd check torque of every bolt that was touched for lift install, but sounds much more like a loose cam bolt on LCA than anything else. I'd start with torques/easiest things to check before diving into other things.
    bttrbsch[QUOTED][OP] likes this.
  19. Jan 19, 2022 at 5:47 PM
    Smolder
    Smolder New Member
    2016 Black TRD OR
    Recently had a similar issue. After lift installed popping noises coming mainly at starts and stops and especially when turning the wheel and beginning to roll (like pulling out of parking spot). Tried several things and thought I had it when I removed the sway bar. But it ended up being the lower control arm to frame nuts. They where REALLY loose. The alignment shop must not have torqued them correctly. Torqued them all to 135 ft lb and noise is gone. Good luck
  20. Jan 19, 2022 at 10:35 PM
    bttrbsch
    Michael
    Bellingham, WA
    Had a rainy evening and nothing going on so decided to tackle this mystery clunking noise. My process of problem-solving:
    1. Lower ball joints & tie rods: Raised the front of the truck off the ground and grabbed the wheel at 12-6 and 9-3. No movement. Also used a pry bar to see if I could initiate any play.. nothing. Visually inspected lower ball joints and tie rods.
    2. Brakes: Went to AutoZone and picked up "disk brake quiet" (basically thick grease). Removed pins and pads, cleaned, lubed up metal-to-metal contact points with the grease and reassembled.
    3. CV Axles: Inspected boots and felt for any play. None found.
    4. LCA torque: Double-checked the torque on LCA bolts. One rotated maybe a quarter of a turn, though I think it was simply moving from ~100 ft.-lb. to ~110 ft.-lb.
    Buttoned it all back up and went for a 3 mile drive to get pizza and fuel up. No clunk noise was heard!! I'm not sure what was the contributing factor. Either the brake grease or slightly tightening the LCA bolt.
    That said, it was only a 5 minute drive... but hopefully it stays away for good. I will continue to monitor and update this thread accordingly. Thanks all for your suggestions and contributions!
    Shadowhunter likes this.
