Noise when losing traction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mwrood, Feb 18, 2021.
  1. Feb 18, 2021 at 6:45 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    For the traction control, ABS, or VSC to operate it must run the pump. Not sure how loud or how severe these vibrate in the Sport but there is an electric motor turning on to run a pump during these events.
  2. Feb 18, 2021 at 7:11 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    I know exactly the noise you are hearing. It is a small electric motor turning on to activate the abs pump. However, you have enough throttle control it seems to have the electric motor to turn off before abs/vsc/tcs kicks in. Next time you are out in slippy conditions, floor it in 2h. You will hear the whirring start, the abs kick in, and then when you let off it will stop.
  3. Feb 18, 2021 at 7:24 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    That's interesting. Maybe that's what I am hearing when I hear an almost inaudible taping/flickering sound instead of the harsher tap-tap-tap sound. I typically hear the softer sound when I incur a small amount of slippage while gently accelerating from a stoplight in snow/ice conditions while in 2wd. I'm still hedging my bets that its the brakes being pumped gently, but I have 50 year old ears. Hah!
  4. Feb 18, 2021 at 7:29 PM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Might be the abs pump doin its thing but just to a lesser degree I suppose.
  5. Jan 5, 2022 at 7:18 PM
    ogsanchez0414
    ogsanchez0414 New Member
    Whoever posted this, on his “edit” im having the same issue i have no idea what it is definitely dont think is ABS it has something to do with the gears i think but still unsure. but defined sound comes on when accelerating not breaking. and traction light comes on as well
  6. Jan 5, 2022 at 9:31 PM
    ShimStack
    Ben
    NC
    If the traction light flashes on that means the system is intervening and is either actuating the brakes, cutting engine power, or both.
    BigWhiteTRD likes this.
  7. Jan 6, 2022 at 8:39 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Thread revive...
    ABS disabled only when locker engaged... at least in testing automatics and manuals 4wd trucks from 2016-2017 era, no guarantee applicable for newer MY. Also, I dont think a 2wd OR was ever tested, so I make no claims there...
  8. Jan 6, 2022 at 9:10 AM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    These trucks have open differentials, when one wheel loses traction the ABS system activates and tries to brake the spinning wheel and allow the differential to provide traction to the non spinning wheel. It is quite loud. Toyota call it auto LSD.
  9. Jan 6, 2022 at 11:05 AM
    gudujarlson
    Minnesota
    I tested this the other day. I can confirm that the locker must be engaged to disable ABS brakes on my 2020.
    BigWhiteTRD[QUOTED] likes this.
  10. Jan 6, 2022 at 12:15 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I haven't noticed any unusual noises with the traction control, or abs, but the traction control led flashes on the dash push you can feel when both activate.
