noise when rotating tire on jack stand
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaJuhas, Nov 12, 2023.
  1. Nov 12, 2023 at 1:15 PM
    TacomaJuhas
    TacomaJuhas [OP] Member
    dave
    white 2019 Pro
    So I put the front of the truck up on jack stands today, and noticed that when I spun the front driver side wheel I heard a clicking sound coming from the front diff area. It didnt do this on the passenger side but the driver side it did. Just wondering if this is a normal sound as its rotating the diff or if I have another issue going on. Wondering if anyone else has noticed this.
    Thanks
  2. Nov 12, 2023 at 9:59 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I'm guessing here, but I would posit it is the ADD that makes the difference. The ADD disconnects the two front axels from each other, while one is still connected to the differential. It is likely the differential you are hearing.
  3. Nov 13, 2023 at 5:18 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Are you sure its the diff and not the inner CV joint?
  4. Nov 13, 2023 at 5:22 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The diff doesn't make a clicking sound when turned. I suspect your CV joint is going out.
  5. Nov 13, 2023 at 5:23 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Does the wheel have any physical feedback, like can you feel the click/crunch as you turn it, and when you shake the wheel side to side, is it solid or does it wobble?
    If there's no crunch and it feels solid, it's probably fine.
  6. Nov 13, 2023 at 5:33 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    needle bearing issue??
    MGMDesertTaco likes this.
  7. Nov 13, 2023 at 5:38 AM
    MGMDesertTaco
    grogie and OffroadToy like this.
  8. Nov 13, 2023 at 4:42 PM
    TacomaJuhas
    dave
    white 2019 Pro
    Not exactly sure, the sound was coming from either the diff or somewhere near it. Ill have to get it back on stands to try to pin point it. Thanks man!
  9. Nov 13, 2023 at 4:45 PM
    TacomaJuhas
    dave
    white 2019 Pro
    No side to side or up and down wobble what so ever, just heard a clicking sound somewhere near the diff. as i would rotate the tire. only on driver side, passenger side was quite.
  10. Nov 13, 2023 at 4:47 PM
    TacomaJuhas
    dave
    white 2019 Pro
    I suspected the same, just wondering if any of you noticed the sound on your trucks while rotating the tire while its off the ground. Not sure if that's normal or not?
  11. Nov 13, 2023 at 4:49 PM
    airforceb2cc
    Don
    KCMO
    No not normal. I’m still going with CV though.
  12. Nov 13, 2023 at 6:42 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I would think you should be able to hear the rolling of the spider gears inside the diff when you spin the driverside wheel, but it should not be loud at all (at least with the factory diff anyway, some aftermarket diffs such as ARB can be much noisier).
    If it's a very noticeable noise (can be heard inside while driving), then yeah, needle bearing or a CV joint.
