Noise when steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ATLien, Jan 30, 2015.
  1. Jan 30, 2015 at 10:21 AM
    ATLien
    ATLien [OP] Well-Known Member
    Portland
    2013 DCSB SR5
    Money Pit
    I have a 2013 DCSB v6 and have noticed an intermittent high pitch whine coming from the firewall area whenever I corner relatively hard, or hit a bump while cornering. The noise typically stops a few seconds after the turn/bump and I don't notice any difference in the handling when it occurs.
    Anybody know what this is? Is it something I should be concerned about?
  2. Jan 30, 2015 at 10:23 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Wheel bearings? Does it happen when you corner left? Right? Both? Do you get the noise if you turn full lock while parked?
  3. Jan 30, 2015 at 10:35 AM
    ATLien
    Portland
    2013 DCSB SR5
    Money Pit
    I've primarily noticed it when turning left, but its happened when turning right as well. It only happens when I'm cornering at speed (30-40mph) under decent g-forces. It almost sounds like a small electric motor/pump running.
