Noise. When tires are lifted, shaking it on a 9and3oclock position
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2016taco777, Aug 9, 2017.
  1. Aug 9, 2017 at 4:42 PM
    2016taco777
    2016taco777 [OP] Member
    is this normal?
    I jack up the 2 front wheels (wheels of the ground)and the then place my hands in a 9and3 o'clock position and start wiggling/shaking the tires. Should this make any loud noise?
  2. Aug 9, 2017 at 4:44 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
  3. Aug 9, 2017 at 4:47 PM
    J.M Taco
    J.M Taco Well-Known Member
    Central California
    '17 Tacoma Quicksand DCSB TRD OR 4x4
    Try 12 and 6 o'clock then report back.
  4. Aug 9, 2017 at 4:48 PM
    2016taco777
    none on 12 and 6
  5. Aug 9, 2017 at 4:52 PM
    J.M Taco
    Central California
    You should be ok then as far as the ball joints go, IMO. What are you hearing? Any drive ability issues?
  6. Aug 9, 2017 at 4:55 PM
    2016taco777
    yes, ball joints are ok.
    clunking noise on the front suspension over bumps, etc.
  7. Aug 9, 2017 at 4:58 PM
    J.M Taco
    Central California
    Well thats not good. Whats your setup? Are you lifted?
  8. Aug 9, 2017 at 5:02 PM
    2016taco777
    not lifted, nothing change. 2016 dc 4x4 trd sport
    I don't want to do anything until they fix the noise.
    still under warranty and I did bring it for service, which they said is normal.
    if anybody is having this type of noise then its normal
  9. Aug 9, 2017 at 5:09 PM
    smitty99
    Scottsdale
    Take it to the dealer and let them help you. It's called a Warranty. When that fails call customer service corporate.
    800-331-4331
    ahkouchi likes this.
  10. Aug 9, 2017 at 5:11 PM
    smitty99
    Scottsdale
    File a case with corporate. Number is above.
  11. Aug 9, 2017 at 5:26 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    :cookiemonster:
    smitty99 likes this.
  12. Aug 9, 2017 at 5:38 PM
    J.M Taco
    Central California
    Hard to tell what the problem would be stock. On lifted applications it's sometimes the sway bar hitting the coil spring, in which case a sway bar relocation is in order but on a stock truck...?
    Does your coil spring look like its seated properly on its perch?
  13. Aug 9, 2017 at 5:39 PM
    smitty99
    Scottsdale
    For your particular issue it might be
  14. Aug 9, 2017 at 5:43 PM
    2016taco777
    dealer had change the whole coil/spring and still making clunking noise.
  15. Aug 9, 2017 at 5:47 PM
    2016taco777
    I was thinking it has to do with the TIE ROD
    since I mention shaking the tires on a 9and3oclock position is making the noise
    little tire play(loose?)
  16. Aug 9, 2017 at 5:49 PM
    J.M Taco
    Central California
    You could try to snug 'em up. Or try a different dealership or escalating to a corporate case.
  17. Aug 9, 2017 at 5:52 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    @smitty99 post are always useful. sometimes it is just for a laugh though. In this case, it's both. He posted the number to solve your problem. All Hawaii dealers will tell it's normal. you could drive in with your motor dragging on the ground and your exhaust pipe shooting Heineken and they will say that's normal. That number will help you. Sadly, this maybe your only option to get results brah.
    2016taco777[OP] and smitty99 like this.
  18. Aug 9, 2017 at 6:22 PM
    2016taco777
    @ahkouchi @J.M Taco @smitty99 thank you and I will definitely call csc
    and if anybody would try doing the floor jack on the front and let me know if there
    are any noise,(#1post)that would be helpful.thank you
    ahkouchi and smitty99 like this.
  19. Aug 10, 2017 at 2:12 AM
    ahkouchi
    Andrew
    Big Island Hawaii
    brah, what island you on? see you're from Hawaii. if you on big island i can try help Tried what you asked, no noise
  20. Aug 10, 2017 at 2:55 AM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Calling corporate is my normal first step. They give you things like candy, bags of crisps, fruit snacks, or platinum 125k warranties and 75k Extra Care.
    Yum
