noise while driving, goes away when braking... ??
Discussion in '1st Gen. Tacomas (1995-2004)' started by AlbertaBeef, Aug 5, 2009.
  1. Aug 5, 2009 at 6:00 PM
    AlbertaBeef
    AlbertaBeef [OP] Active Member
    Alberta, Canada
    '96 Tacoma 4x4 Extended Cab
    Revtek 3" Lift
    OK, this is weird... I've noticed some quiet (I feel them more than hear them) clunk-clunk-clunk-clunk... coming from under my feet as I drive...
    It's obviously related to rotation... when I drive it goes faster as I accelerate, and slows as I slow... it seems to make about four clunks per revolution of my tires... (guess)
    The odd part... when I apply my brakes, even slightly, it goes away... totally disappears.
    If I roll the windows down, I don't hear it any louder... Like I said, I more 'feel' it than hear it... but it's there.
    Doesn't seem to change any upon cornering either direction... the only time the sound changes is when I start to apply brakes, even a little bit... then it disappears completely...
    Truck info - '96 Taco 4x4 extra cab V6, 3" revtek lift, 31x10.5x15 TrxUS MT's...
    ... any brilliant ideas? Or tell me where to start looking? (It's been pouring here for days and my garage is full, so I haven't gotten underneath it yet... would like some ideas of where to look...)
  2. Aug 5, 2009 at 6:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Somthing hitting the brake caliper? Caught in the wheel maybe?
  3. Aug 5, 2009 at 6:27 PM
    AlbertaBeef
    Alberta, Canada
    Revtek 3" Lift
    that's what I'm leaning toward... can't get it up on jacks until tomorrow after work...
    ...even then, will be in the rain in front of the garage... Maybe I'll set up a tarp shelter, lol. pretend I'm camping while working on it.
  4. Aug 5, 2009 at 6:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL! I have done that! Let me know what you find. :)
  5. Aug 5, 2009 at 8:47 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    I kinda have the same problem every now and again, But its a beeeeeeeeeeeeeeeeep sounds. when i brake, it goes away. im still trying to figure it out.
  6. Aug 7, 2009 at 6:15 PM
    AlbertaBeef
    Alberta, Canada
    Revtek 3" Lift
    so . . .
    I finally get around to moving stuff away from the garage so I can lift the truck, remove the tires and look for the noise...
    ... and ...
    goshdarnit, the stupid floor jack I have maxes out before it even lifts it. It's too danged low, rofl. (the kind I have is pictured below, lol)
    ... that being said, I did buy them to work on my cars, not a lifted truck... But even so, I feel like a moron now. Can't even jack my truck...
    And now I have to go buy a jack that actually raises my vehicle.
    Oh, and I also noticed I have skid plates covering the entire underside of my truck, can't even get to the crossmember jack point, rofl. It's under there somewhere. I guess that's a good thing, armor... except when it's in your way...
    and yes, this is the FIRST time I've ever been under this truck.
  7. Aug 7, 2009 at 6:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Keep us posted....:)
  8. Aug 7, 2009 at 6:48 PM
    mcgiiver
    mcgiiver Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    I had a similar noise on an old VW. I was just about to replace the transaxle when I discovered the lug nuts were loose. Problem solved.
  9. Aug 26, 2009 at 6:21 PM
    AlbertaBeef
    Alberta, Canada
    Revtek 3" Lift
    OK, so ... finally got myself a nice hydraulic jack, and got the truck into the air and on jack stands...
    Pulled the wheels, removed the calipers, inspected everything... (my flex hoses are a little cracked... but that's no biggie...)
    ... now here's the weird part... after uninstalling / inspecting everything, I couldn't see a cause for the noise... I put it back together again, and...
    voila ...
    Noise is gone. :eek:
    WTF??
    I'm not going to complain... pretty sure something wasn't quite assembled right with my front calipers/pads, and that removing/reinstalling it fixed it... But ... wow. Weird.
  10. Aug 29, 2009 at 6:05 PM
    2004Taco
    Lou
    California
    Lol Voila! i like that.
  11. Aug 29, 2009 at 7:07 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    :laugh: That's what I was thinking when I read it.
