Noise ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by imorlock, Aug 17, 2010.
  1. Aug 17, 2010 at 1:28 PM
    imorlock
    imorlock [OP] Member
    Ian
    Gold Hill, Colorado
    03 Tacoma SR5 4cyl. 4x4
    Hey everybody. I have a 2003 Tacoma and am having some strange noises that seem to be getting a little louder recently. Any help would be great.
    The one that is most audible right now is a sort of scratching (like a stick against the pavement) that starts at about 30mph and is a consistent scratching sound until the truck is stopped. It sounds like a cricket chirping at times but not so high pitched. Almost seems like there are always pebble in the tires, which there are not! Anyway, I have heard some low humming and rotational vibration under the seats for some time now, but 3 different mechanics have chalked that up to road noise, which I still don't believe cause I have had 2 different sets of tires now and the sound it always the same.
    I guess I am concerned that the humming is in the drive shaft, but I can't seem to begin to thing what this scratching may be. Any suggestions out there on what to look for?
  2. Aug 17, 2010 at 1:59 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    check your pads
  3. Aug 17, 2010 at 2:19 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    is your disc brake shield rubbing anywhere, that sound wouldnt be coming from under the seats obviously but it does make a nasty scratching sound.
  4. Aug 18, 2010 at 10:55 PM
    imorlock
    Ian
    Gold Hill, Colorado
    Pads are good.
    I will check the shields this weekend when I can put the wheels up and have s look. Get back to you after that.
    Thanks so far y'all.
  5. Aug 18, 2010 at 11:46 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I was thinking tires first, and brake shield/brake area second after reading your description, as those are usually the areas that contains wear items.
    Of course it could also be something silly like some plastic molding came loose and is rubbing (a lot of people have paid lots of money replacing parts and looking for problems when its been something really stupid that people just dont think of checking). Look for any wear marks in your wheel wells, mud flaps, and all along your drive line and front axles. Then there's also the people that I've heard will put zip ties on the drive line as a joke.
    Are you running oversized tires? 285 width tires come really close to the UCA on stock wheels and if something is out of alignment or the ball joint is failing, I could see some rubbing happening pretty easy.
    Does the noise seem to get worse the faster you go, after you press the brakes, or any other activity, or is it pretty steady?
    If that doesn't work out, have you tried jacking up the truck to see if you can narrow it down a little bit more? There's just way too many moving parts that it could be.
    Some other options at the top of my head (besides brakes and tires). They all should be pretty easy to diagnose one wheel at a time.
    Wheel bearings
    Front axles/cv joints
    u joints on drive shaft
    Then you get into the more involved areas like diffs, transmissions, and transfer cases.
  6. Aug 19, 2010 at 12:20 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Lube up your Drive shaft?
    I didn't grease mine for a while and it started making this LOUD ANNOYING SCRATCHING SOUND. greased it til the grease was squeezing out and the sound went away.
