noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crewdog, Dec 3, 2010.
  1. Dec 3, 2010 at 6:41 PM
    crewdog
    crewdog [OP] Active Member
    mike
    chicago illinois
    2005 tacoma
    K&N induction, Borla catback,885's & Dakkars grillecraft BLH
    my o5 is starting to get a noise/slight vibration in the front that I notice around 50mph. Slight turn of the wheel to the right and it goes away. could this be carrier bearings. Curious because I'm lookig at doing 3" of lift
  2. Dec 3, 2010 at 9:09 PM
    yodaman
    yodaman Active Member
    Bellingham
    07 TRD Sport 4x4 V6 Automatic
    Yokohama tires Skyjacker canopy add more later
    Hello, your lucky the noise goes away when you turn your wheel. That means it something other than your driveline.
    I don't think it's your carrier bearing. The noise wouldn't likely go away when you turn your wheels. Have you had your tires checked? Get them balanced and checked for flat spots. Have them rotate the tires to isolate the noise. Especially if the noise/vibs increase to 50mph. Then it's likely tires. There are other issues such as bearings and what have you but I'm betting on your tires.
    You can drop you carrier bearing with washers if you want to test that theory.
    Good luck.
  3. Dec 3, 2010 at 9:19 PM
    747 function > form
    1st Gen.
    ^this, imho.
  4. Dec 3, 2010 at 11:04 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    if it goes away when you turn i'm betting wheel bearing
  5. Feb 1, 2011 at 10:17 AM
    FuzzyRuttin
    FuzzyRuttin Blue Barchetta
    Russ
    Syracuse NY
    05 TRD Sport 4x4 stick
    Got 05 with exact same symptom. Crewdog, what have you found?
