Noisey Blower Motor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1ugly baby, Oct 27, 2010.
  1. Oct 27, 2010 at 2:20 PM
    1ugly baby
    1ugly baby [OP] Active Member
    Pat
    Fountain, CO
    Tacoma TRD Off Road
    OME 886 FRONT Dakkar rear
    Is it normal for tacoma's to have a noisey blower motor? There is no noise in the A/C mode. The noise is almost a whistling, when the heater or defroster is on. Any ideas?
  2. Oct 27, 2010 at 3:08 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    If it's like a chirping sound when the temp is cooler outside, there is a TSB on this. Toyota will put in a modified blower motor. I had this done 2 weeks ago and it's perfect now.
  3. Oct 27, 2010 at 3:11 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    i had mine replaced as well. only made a squeal on the low 1 and 2 settings while a/c was on. i didn't realize there was a published TSB on the problem though. the new blower motor does not squeal.
  4. Oct 28, 2010 at 6:09 AM
    1ugly baby
    Pat
    Fountain, CO
    Tacoma TRD Off Road
    Thanks for the info. I'm going start researching that. I hate when I go to the dealership and they look at you like your on crack when you ask if there are any tsb's of any type concerning my truck.
  5. Oct 28, 2010 at 6:18 AM
    fjrmurph
    fjrmurph Well-Known Member
    My 2010 is doing the same thing, only in low speed. If you find the TSB please post it here
    THKS
  6. Oct 28, 2010 at 6:35 AM
    Glamis
    Glamis date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    I'm on my 3d blower motor. Toyota just keeps putting them in.
  7. Oct 28, 2010 at 7:01 AM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    Sub.
    Hope someone finds the TSB # this has been driving me nuts for months
  8. Oct 28, 2010 at 8:59 AM
    1ugly baby
    Pat
    Fountain, CO
    Tacoma TRD Off Road
    This is what I have found so far. alldatadiy.com just has a title. I am having a hard time verifying if this is the real tsb or if it is theirs. The TSB # they have posted is, SB0092. I don't want to pay for a subscription when Toyota should publish it. Is there any Toyota Techs here that can verify this. Thanks in advance.
  9. Oct 28, 2010 at 9:15 AM
    HubbaBubbaGump
    HubbaBubbaGump Member
    Carlos
    Katy, Tx
    06 Prerunner SR5
    The blower motor in my truck makes a ticking noise, most noticably at the lower settings. I did check the air cabin filter and there were small pieces of debris (leaves, pine tree seeds, etc ). I took the blower out and inspected it and it was fine. It may have been something caught up in there prior to changing the cabin filter.
  10. Oct 28, 2010 at 9:33 AM
    fjrmurph
    Are you saying you have no noise after cleaning the filter?
  11. Oct 28, 2010 at 9:41 AM
    HubbaBubbaGump
    Carlos
    Katy, Tx
    06 Prerunner SR5
    Much less....there may be a small particle still in there. It comes and goes, which is why I say that. I didn't realize how dirty these cabin filters can get. I change it every 6 months or so. I just changed it last month and saw that it was a bit yellowish, probably from all the pollen.
  12. Oct 28, 2010 at 12:48 PM
    knayrb
    Bryan
    Pure stock
  13. Oct 28, 2010 at 12:54 PM
    TexasBlue
    TexasBlue Dreamer
    Kellan
    Dallas, TX
    07 PreRunner Sport, Speedway Blue
    Billet Grill, Roll-Top Cover, LED Interior Lights, HIDs, Foglight On Mod, Coin Tray Holster Mod
    The chirping at low-speed is due to the bearing on the bottom of the blower motor losing lubrication and wearing out. I went through a couple of different processes to fix this. Luckily the blower is easy to get to under the dash with just 3 bolts and one wire harness to unplug.
    Following some tips on here, I first disassembled the motor and polished / greased the bearings. This worked for a while, but then it made the noise again. So I ordered an OEM replacement off the internet and did a direct bolt up of the new part. That was a year ago and no problems since.
    I'd go the TSB route if you're under warranty, otherwise it's an easy do-it-yourself fix with the parts being relatively inexpensive.
  14. Oct 28, 2010 at 12:59 PM
    fjrmurph
    Thanks this should make it easier when i go to the dealer
  15. Oct 28, 2010 at 7:45 PM
    Frogdaddy
    Frogdaddy Well-Known Member
    Ga.
    2010 PreRunner SR5 DC
    Pioneer MVH-p8200 hu with XM receiver using TSS supplied shark fin cable, Mud Flap cut mod.
    tsb. Did it after I had mine about two months. Low speed heater chirp. Haven't heard it since. We'll see this winter. Get it done. They had to order mine after checking it.
  16. Oct 28, 2010 at 8:37 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    where did you buy this part? My crickets are back after 7 months of greasing the bearings.
  17. Oct 29, 2010 at 6:23 AM
    1ugly baby
    Pat
    Fountain, CO
    Tacoma TRD Off Road
    Thanks for the info, it was starting to become time consuming.
  18. Oct 29, 2010 at 6:27 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    question about this, I had mine replaced at 2x,xxx miles and now it is doing it again but I am at 47k, could I get it replaced by toyota or am I SOL on this one.
  19. Oct 29, 2010 at 6:55 AM
    knayrb
    Bryan
    Pure stock
    Even though you are out of the 36,000 warranty, I would argue that you only have 20K+ miles on the new one. I would say they didn't give you the new part number but instead got the original motor part out of inventory.
    You are probably going to lose but it's worth a try. Good luck. At least if you buy a new one take the TSB with you and get the recommended part number.
  20. Nov 4, 2010 at 10:43 PM
    808Koma
    808Koma Active Member
    Honolulu
    08 SPORT TRD 4x4
    I am having this issue i think i am at around 25k and i get it when i turn the truck on and then i get it between 1.5-2k RPM. I have never taken the truck in for a TSB so i am not sure on if i just call the locals or do i call toyota to set me up? thanks for the help
