Noisy 4L. engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Speedway blues, Aug 28, 2024.
  1. Sep 10, 2024 at 10:52 PM
    TacoTuesday1
    SD CA
    did you check the valve clearance
    did you do the VSV tick mod/fix
    pretty sure gas door says 87. 91 or higher is required on forced induction which the 1GR-FE stock is not.
    That being said, makes me wonder if something like Shell 87 would be quieter than Costco 87. I use Costco as it's cheapest. Like $2.95/gal 87.
  2. Sep 10, 2024 at 11:17 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    COSTCO gas is TopTier™. For whatever that's worth. There are also a lot of budget brands on the "TopTier" list.
    https://www.toptiergas.com/gasoline-brands/
    2024OffRoad likes this.
  3. Sep 11, 2024 at 9:13 AM
    ieizxxnsaeomeostfd
    ieizxxnsaeomeostfd Well-Known Member
    2014 Tacoma Base
    ARB Bumper Warn winch Icon lift 35s
    That's what fixed the issue for me (if I had the same issue OP is having). I didn't notice it until I was in a really hot climate at low altitude, didn't matter what gas I put in it. After getting the ECU re-flashed the problem went away.
    For me I only heard the noise at low rpms while the engine was under load.
    I did have to fight with a dealer a bit to get them to do it, once I showed them the TSB they re-flashed it - I was still under the applicable warranty at the time (this was years ago).
    Williston[QUOTED] likes this.
  4. Sep 11, 2024 at 12:27 PM
    TacoTuesday1
    SD CA
    sounds like time to work at Toyota for a whole week to connect Tacoma to their computer.
    otherwise it’s $230/hr 1hr-min typically per flash, “diag”, etc IF they even do anything at all.
  5. Sep 11, 2024 at 12:32 PM
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Thanks for the update and confirmation: appreciate it. You explained the issue better than I did and it sounds like the scenario you provided. The TSB has a sticker they were supposed to put on the inner hood surface near the driver's side for I would guess is for emissions. (modification). Like I noted previous, no sign of this on my hood. I also have a very-detailed history and service history of the truck that a nice dealer ran and gave to me one time, and while at least one other TSB shows in it related to the rear springs, no sign of this one; and honestly: I would be willing to pay for it if it's not some ridiculous amount of money.
  6. Sep 11, 2024 at 12:35 PM
    ieizxxnsaeomeostfd
    2014 Tacoma Base
    I can't imagine it'd cost much, it's just an ECU flash. I've never done one personally on my Tacoma but I've flashed other cars. Just plug a computer into the OBDII port, hit a button, wait a few minutes and it's done.
  7. Sep 11, 2024 at 12:37 PM
    TacoTuesday1
    SD CA
    At the dealer.
    Dealers are hour minimum.
    Hourly rate is ~$230.
    repairs are often diagnosis. Plus repair. Separate lines.
    some flashes take half an hour. Some take 4 hours.
    if this update even applies to the truck VIN.
  8. Sep 11, 2024 at 12:43 PM
    ieizxxnsaeomeostfd
    2014 Tacoma Base
    Yeah that's a good point. I avoid going to the dealer whenever possible and do all my own work so I'm not well versed in their cost, nor would I like to be. I think the last time I went to one was for this and it was covered under warranty.
    Also, for what it's worth, OP - I just checked my truck and they didn't put the sticker under the hood so that's not a reliable way to tell if you've got it or not it seems.
    Williston likes this.
  9. Sep 11, 2024 at 1:43 PM
    TacoTuesday1
    SD CA
    this reminds me
    I have OTT
    so probably better than factory and no need for dealer shenanigans
    Not much higher cost than dealer
    But actually getting something out of it.
  10. Sep 21, 2024 at 9:35 PM
    FJC MAN
    FJC MAN Active Member
    Bill
    2007 FJ Cruiser
    Jason, a valve adjustment is more involved than replacing a shim on the valve follower/bucket. The follower is the shim. The camshafts have to be removed, then the corresponding follower has to be measured to calculate the correct thickness replacement.
