Noisy 4x4?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by littlewhiteyota, Oct 16, 2014.
NOISY 4X4?
Poll closed Nov 15, 2014.
  1. Am I just being paranoid?
    72.2%
  2. Is it just normal?
    44.4%
  3. Is it a problem?
    0 vote(s)
    0.0%
  1. Oct 16, 2014 at 1:17 PM
    littlewhiteyota
    littlewhiteyota [OP] Active Member
    Max
    topanga CA
    2014 4x4 tacoma single cab
    Hey guys I am new to Tacoma World and a new owner of a 2014 regular cab 4x4 tacoma!!!!!!! its my first vehicle!!, I bought it two months ago and have started doing bite of 4wheeling with it, nothing to hard just some easy trails and such. I have a few questions that are not answered so well in the owner manual.
    1. I heard that turning off traction control while in 4x4 will better the preformance is that true? and should I do it?
    2. I know that when shifting into 4low I have to be in nutral with the parking break on I also know that I can turn on 4high while moving under 55 mph, how ever when I turn on 4high while moveing really slowly it makes a loud CLUNK, I only noticed it the last few times I have turned it on. What is it? I read that turning on diffs can be loud but I dont have one. Its really concerning. I read on Tacoma World that one guy puts his truck in nutral while moving and shiftes his truck to 4high.
    3. the last question, I did some minor flexing the other day and heard some CREEKS and CRACKS, again I refered to Tacoma World and read that its just the leaves stretching, does that sound right?
    I am very paranoid about treating my truck with love and just want to make shure i am not hurting her, also if there is any other things to be aware of please inform me!!!!!
    Thanks for taking the time.
  2. Oct 16, 2014 at 3:13 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Welcome
    first off the traction control should automatically turn off once 4wd is engaged, secondly 4 hi is useless forget it exists!!!, also I personally hate the traction control on my 09 I'm looking for a way to disable it full time
    question 2, you don't have to have the parking brake on it'll work without it, but you will need to be in neutral with the clutch depressed to the floor, shift to 4 hi wait for the light to be solid you may have to roll forward a bit sometimes for the front diff to engage, make sure you're stopped then shift into 4lo, never ever ever attempt to shift into 4 lo while moving seriously!!!!!! I don't even shift into 4 hi while moving.
    question 3
    when you flex the truck its going to make noises!!! don't worry if it still runs and nothings leaking you're good to go!!! just wait till you can hear the roof and a pillar creaking :)
  3. Oct 16, 2014 at 6:51 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    1) Turning the traction control off while off-road is recommended...AFTER you get some experience behind the wheel.
    2) A slight to moderate clunk is somewhat normal when engaging 4HI while moving. Just make sure you are not spinning the rear tires when engaging. A clunk when stopped and shifting into 4LO is completely normal.
    3) The truck will make noise as you use it. Normal.
    Um...wut?
  4. Oct 16, 2014 at 6:59 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Wtf? 4Hi is not useless by any means.
    OP, definitely read your manual. There is some very useful information that will help.
    GL
  5. Oct 16, 2014 at 7:07 PM
    Paleus
    Paleus Well-Known Member
    Arkansas
    '13 DCSB TSS 4x4
    How the heck is 4Hi useless? In flat ground, low traction situations, it would be more useful than 4Lo.
  6. Oct 16, 2014 at 10:00 PM
    TYetti
    Mat
    I've never once used 4hi if I need to be in 4x4 then 4lo is what needs to be happening all 4hi does is engage the front wheels, when needing traction I usually need better gearing as well thus 4lo, but that's trail situation not parking lots, op was talking about some beginner trails in my experience 4hi just puts drag on the driveline
  7. Oct 17, 2014 at 5:45 AM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    4 hi is useless, I needed a good laugh.
  8. Oct 17, 2014 at 5:46 AM
    dm1215al
    Dan
    Fl
    4 Hi is useless, I needed a good laugh, thanks.
  9. Oct 17, 2014 at 6:07 AM
    TugBoatTrash
    TugBoatTrash Face first!! Hammer down!!!
    Bob
    E. Freetown MA
    15 DC Tundra SR5
    Do dents and scratches count?
    Both 4wd modes have their uses on and off the street.
  10. Oct 17, 2014 at 8:17 AM
    MagnumTaco
    MagnumTaco Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
    4 lo traction control off is better. The parking break does not need to be engaged to engage 4wd. You can only turn on slick surfaces when in 4wd. If you're turning while in 4wd and on a dry hard surface your drive line will bind up and possibly cause damage to vehicle and/or tires. The truck will flex, it is normal. The skid plates like to pop when they flex.
  11. Oct 17, 2014 at 9:27 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Without 4 Hi I'd not have been able to drive in the winters during/right after decent snow storms. You often can do the flat roads in 2WD but parking lots, (Especially NE Hilly terrain) ,snow berms/banks etc. require 4WD in my empty truck u less I want to get out and push !!!!
  12. Oct 17, 2014 at 9:29 AM
    TYetti
    Mat
    Just my experience, if you can show me situations where 4hi comes in handy I'd be happy to go try it out, it has been my experience that as soon as you are in a position to need 4hi two seconds later you need 4lo, I prefer 4lo because I take advantage of the gearing
  13. Oct 17, 2014 at 10:25 AM
    TYetti
    Mat
    Fair enough I could also say auto problems!!! With the 2.7 5spd 4hi is just a clutch burner imo, in 4lo with the manual I can just keep shifting if I start to break traction, I can understand how that would be an issue with an auto, op also never mentioned which enginengine he has. I'm gonna have to try this out though just cause now I'm curious if it will work with my truck or not
  14. Oct 17, 2014 at 10:29 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    4 hi is very useful. How else would I drive 45 miles an hour UP the mountain in the snow?
  15. Oct 17, 2014 at 11:32 AM
    TYetti
    Mat
    In 4lo 5th gear
  16. Oct 17, 2014 at 11:45 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How do you live in BC and consider 4HI useless ? You don't use it in the snow ?
    Disable ABS and VSC / Traction Control
    http://www.tacomaworld.com/forum/2n...locking-diff-write-up-pics-8.html#post5324525
    Also there is no issue shifting into 4HI while moving and even if you did try to shift to 4LO while moving the truck won't let you do it anyway
  17. Oct 17, 2014 at 11:56 AM
    TYetti
    Mat
    Sweet thanks for the link! !!
    It snows in the lower mainland ?
    Lol all I'm saying is every time I went to use 4hi I ended up stopping and using 4lo, if I run into some snow or mud I'll try it out and see what happens but I'm guessing I'll get stuck and revert back to 4lo
  18. Oct 17, 2014 at 11:57 AM
    OZ-T
    Peter North
    British Columbia
    They are for 2 different applications
  19. Oct 17, 2014 at 4:29 PM
    TYetti
    Mat
    Well I haven't found an application for one of them
  20. Oct 17, 2014 at 4:43 PM
    Canufixit
    New England
    Perhaps using both Hands ??
