Noisy belts...
Discussion in '1st Gen. Tacomas (1995-2004)' started by HER99TOYota, Jun 23, 2009.
  1. Jun 23, 2009 at 8:29 AM
    HER99TOYota
    HER99TOYota [OP] Active Member
    Utah
    White 99 PreRunner SR5
    3" Revtek lift, 17" chrome MotoMetal wheels with 32" Dick Cepek Mountaincat Radial tires!
    The belts on my truck are always making noise and it drives me crazy. What can I do to fix the problem? I tried belt lube and I honestly think it made the noise even worse ha ha. Any suggestions?
  2. Jun 23, 2009 at 8:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Replace them with new belts?
  3. Jun 23, 2009 at 8:34 AM
    HER99TOYota
    Utah
    Thanks for the quick reply! Should I replace all of them and how difficult is it to do?
  4. Jun 23, 2009 at 8:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its not hard. You should replace all of them to be on the safe side. :)
  5. Jun 23, 2009 at 9:03 AM
    HER99TOYota
    Utah
    I will probably change them this weekend and see how it turns out! Thanks!
  6. Jun 23, 2009 at 5:51 PM
    hardtaco
    hardtaco Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    Since our trucks do not have auto belt tensioners on them, you may want to adjust the components so that your belts are tight. I still can't believe that they don't have belt tensioners on them. Oh well.
  7. Jun 23, 2009 at 5:55 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    ARe you sure its the belts sqeeking?
    When are they making noises? All the time? Only at startup?
    THe A/C idler pulleys on the 3.4L are known to go bad. THe bearings go bad and start squeeling. Also, any of the bearings on any of the pulleys can go back. You need to determine if you have bad bearings and which ones.
    If you're changing the belts, take the time to spin each pulley by hand and FEEL them. Feel for rough spots and if they're loose. Pulleys should spin smoothly and freely without any play side-to-side.
  8. Jun 23, 2009 at 5:57 PM
    Janster
    Jandy
    Lancaster, PA
    When there's 3 belts....I can only imagine its cheaper to make the components adjustable versus a fixed component & additional pulleys involved.
  9. Jun 23, 2009 at 6:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, the second gens have auto tensioners. :)
  10. Jun 23, 2009 at 9:15 PM
    HER99TOYota
    Utah
    My belts squeek all the time. It makes my truck sound like a piece of crap...for one, its a toyota and two....we all know toyota is the BEST :D If they squeek all the time, is it definitely the belts?
  11. Jun 23, 2009 at 9:41 PM
    Cheesycook
    Cheesycook Geek with a gun
    Hermiston, OR
    01 4x4 DC Tacoma V6
    If you are getting new belts I would recommend spending the extra couple of bucks for Gator Back belts. I started using them in my old 88 Wrangler and refuse to use anything else since. They seem to last forever, grip well, and never slip.
  12. Jun 24, 2009 at 2:37 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    Nope, only if the truck is running. If it's squeeks when truck in not running, you may have mice. :eek:
    Sorry, I had to... :D You did say "All" the time......:D
    99% sure it should go away with new belts. Although, it could be a pully or tensioner bearing. Unlikely though.
  13. Jun 24, 2009 at 2:44 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Adjust them first. I went through this exact thing a while back.
  14. Jun 24, 2009 at 3:27 AM
    Janster
    Jandy
    Lancaster, PA
    Are you reading any of the responses? Are you doing anything to look at them?
    Here's mine again....from a previous post.
    THe A/C idler pulleys on the 3.4L are known to go bad. THe bearings go bad and start squeeling. Also, any of the bearings on any of the pulleys can go bad. You need to determine if you have bad bearings and which ones.
    To add:
    Belts don't normally squeel or squeek on their own. When belts squeek, it's usually when they're too loose and they squeek at 'startup' when the torque load is higher.
  15. Jun 24, 2009 at 2:18 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    they do squeel on there own. When there old and stretched out..I can't count how many ive done on rangers and such, and the squeel went away after a new belt, but they also have auto tensioners.
    Try new belts and see if that works out, just make sure to check everything while your there to make sure its no pulleys or anything.
  16. Jun 25, 2009 at 2:15 PM
    HER99TOYota
    Utah
    Yes, I am reading ALL of the respnses. Am I s'pose to check this stuff with or without the belts on?
  17. Jun 25, 2009 at 5:43 PM
    Janster
    Jandy
    Lancaster, PA
    You have to take the belts off.
    You mentioned you were gonna change the belts this weekend...(see below)
    So that'll be the perfect time to check all the bearings/pulleys.
  18. Jun 26, 2009 at 10:26 PM
    HER99TOYota
    Utah
    My point exactly...the weekend hasnt even gotten here yet and you are asking me if I am doing anything to check things out. I had read all the responses but since I hadnt taken the belts off yet, there was no progress to post. Im not gonna have time this wknd but possibly during the week. I will post the progress as it accures! Thanks again for all the response :D
  19. Jun 26, 2009 at 10:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, Janster is right in that it sounds more like a pully, than the belts. If the squeak is always there, its a pully. Belts will squeak, but often go away after warm.
  20. Jun 27, 2009 at 9:58 PM
    HER99TOYota
    Utah
    Sounds good! If it is a pully, how much do they cost to replace and is it difficult? I will hopefully find time to do it during the week, but if its too pricey, I will have to wait...
