Noisy CA's?? Helppp meeeee
Discussion in 'Suspension' started by tacos_modern_life, May 14, 2017.
  1. May 14, 2017 at 1:17 PM
    tacos_modern_life
    tacos_modern_life [OP] Well-Known Member
    Brandon
    Portland, OR
    2015 Inferno TRD Pro
    TRD S/C, afe/TRD intake, TRD exhaust, Work Meisters, Retrax, Baja Designs Amber Fogs
    hey guys!
    Not a master mechanic but I do most of my own maintenance and part add ons. Anyway, I've been having this almost chirp-like noise coming from my front wheel wells while daily driving. It begins at about 10mph and seems to be happening when any type of movement happens with the suspension. Braking does not help. I live in AZ and travel dirt roads when I get out of town to camp and thing like that. I've tried using lubricant on the UCA, LCA, ball joint, etc. nothing seems to help. I've also noticed that the flimsy rubbery engine bay covers in the wheel well are help in by rivets. Could these cause the noise? I have 72K on my original tx pro suspension. Any ideas?? This noise suckssss when the windows are down lol
  2. May 15, 2017 at 9:45 AM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    Check and make sure all of the components are tight.
    I had this happen to me. VERY annoying!
    I checked my brakes first and realized my pads were sitting a little lose...tighten those up. Then I noticed my sway bar end links were loose as well. Tighten everything up, no more sound.
    Anther thing to check are your wheel bearings.
    JT
    tacos_modern_life[OP] likes this.
  3. May 15, 2017 at 10:32 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    Might sound crazy but I had something similar and it ended up being my ERG in-channel window guards. Didn't realize what it was until I swapped out to new suspension and the noise was still happening.
  4. May 15, 2017 at 10:04 PM
    tacos_modern_life
    Brandon
    Portland, OR
    Thanks for the input guys! I'll check it all tomorrow. This noise is killing me slowly hahaha
