noisy diff
Discussion in '3rd Gen. Tacomas (2016-2023)' started by noisydiff829, Jan 9, 2024.
  1. Jan 9, 2024 at 12:09 PM
    noisydiff829
    noisydiff829 [OP] Member
    23 super white OR DCLB
    wanted to know if anyone ever found a fix for the notorious howling diff issue on these damn trucks. I drove through mud once and now it won't shut up, 13k miles were perfect until it started making noise.
  2. Jan 9, 2024 at 12:11 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Whats the fluid look like?
  3. Jan 9, 2024 at 12:18 PM
    noisydiff829
    i haven't checked yet as i started on sunday but i'll take a look when i get home, what shouldn't it look like ?
  4. Jan 9, 2024 at 12:23 PM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    Not much you can do because its resonance. I had mine swapped out from the dealer and it started howling right out of the parking lot. Someone on here stated that if you change something in the rear end ie. leaf springs, shocks etc it might go away. My sweet spot is 53mph.
    Chew likes this.
  5. Jan 9, 2024 at 12:25 PM
    FLAK-TAC
    SW Florida
    2022 TRD OR LB
    …I even changed my diff oil to Amsoil severe gear 500 miles after the new one was installed.
  6. Jan 9, 2024 at 1:35 PM
    PTPinETN
    PTPinETN Well-Known Member
    Alan
    ETN
    Was 56 for me, but the rear locker had been slow to engage and when it finally stopped engaging I took it to the dealer (20k miles).
    Replaced under warranty and so far there’s been no more whining and I’m at 23k now.
    FLAK-TAC[QUOTED] likes this.
  7. Jan 9, 2024 at 1:48 PM
    FLAK-TAC
    SW Florida
    2022 TRD OR LB
    What stopped engaging?
    Locker?
  8. Jan 9, 2024 at 1:52 PM
    PTPinETN
    Alan
    ETN
    Yes, sorry I wasn’t clear.
    The locker wouldn’t engage at all, the red light never came on solid- only blinked.
  9. Jan 9, 2024 at 1:53 PM
    FLAK-TAC
    SW Florida
    2022 TRD OR LB
    Weird.
  10. Jan 9, 2024 at 1:55 PM
    PTPinETN
    Alan
    ETN
    Agreed, and no issues at all at the dealer, came out and told me they were swapping it under warranty and they’d be happy to get me home. No issues since- whining or engaging.
  11. Jan 9, 2024 at 2:01 PM
    noisydiff829
    that's weird oddly enough i've never used my locker since i bought the truck. how fast should the locker engage ?
  12. Jan 9, 2024 at 2:02 PM
    noisydiff829
    ive also heard harmonics was the main issue but that just sounds like an excuse to upgrade my suspension
  13. Jan 9, 2024 at 2:03 PM
    FLAK-TAC
    SW Florida
    2022 TRD OR LB
    Not a terrible excuse!
    noisydiff829[OP] likes this.
  14. Jan 9, 2024 at 2:04 PM
    FLAK-TAC
    SW Florida
    2022 TRD OR LB
    There’s quite a few threads on here that go more in depth on this topic.
  15. Jan 9, 2024 at 2:35 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If you are sitting still it could take an infinite amount of time depending on a few factors. If you are driving slowly (< 3mph) it usually takes only a second or so.
    Chew likes this.
  16. Jan 9, 2024 at 2:40 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  17. Jan 9, 2024 at 3:14 PM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    Mine has howled since I bought it with 7 miles. Does it from about 52-58mph under real light throttle. You’re saying that’s not normal?
  18. Jan 9, 2024 at 3:28 PM
    noisydiff829
    it shouldn't be considering it never made that noise for 13k miles, it stated this sunday on my way home when i took it mudding
  19. Jan 9, 2024 at 3:34 PM
    gudujarlson
    Minnesota
    Can you share more details about this “mudding” episode?
    A more detailed description of the noise you hear would be helpful as well.
  20. Jan 9, 2024 at 3:42 PM
    Darkice
    Darkice Well-Known Member
    I've been chasing this issue since i got my Tacoma in 2020. bought new and had it regeared to 4.88s. the new gears made an awful noise at freeway speeds and the shop ended up redoing the rear gears again 1 year later. it still had a very loud harmonic hum at freeway speeds. things i did to remedy the issue.
    • replaced gear oil with Lucas 85-140
    • installed Tacoma Dynamic Damper onto the rear cab mounts Part# 51229-04010 x2
    • installed Dynamat sound dampening material against the back cab interior and back half of floor. i also used the closed cell foam on top of the Dynamat.
    • Installed beefier tires, these tires make more road noise and drown out the diff hum. :rofl:
    After all this, i can still hear the gear whine / hum a bit but it's much improved. it really doesn't bother me that much now. i would at least start with a thicker oil, its cheap and easy to do. the thicker oil will cushion the gears so they doesn't resonate as much.
    The dynamic dampers helped a little but not as much as i would have liked. some people have better results with these than i did.
    The sound dampening material helped more with road noise than the actual gear hum but still helped a little.
    this was a lot of work but everything combined helped mitigate the noise.
    bulalo likes this.
