Noisy Engine
Discussion in 'Technical Chat' started by TruckGuy21, Dec 2, 2021.
  1. Dec 2, 2021 at 1:39 PM
    TruckGuy21
    TruckGuy21 [OP] New Member
    Emery
    2021 VooDoo Tacoma TRD
    Just got back from the dealer,not very happy with Toyota,my new tacoma with 2500 miles sounds like a diesel,Dealer says that is normal injector noise, if so Toyota needs to do something.$50.000 and ashamed to drive my truck,pull into bank drive thru,I was asked what is wrong with my new truck, very unhappy, owned Toyota all my life, NO PROBLEMS, I'm a journeyman mechanic 30 years.this noise is not normal, maybe time to talk to a lawyer !!??
  2. Dec 2, 2021 at 1:45 PM
    SteveinFL
    SteveinFL Well-Known Member
    Stephen
    2021 Black Tacoma SR5 4X4
    Hard folding tonneau cover, running boards, mud flaps, locking tailgate, tinted windows
    My 2021 (6 Cylinder) was a little loud (out of what I think of as normal range for noise) with injector noise, but has since settle down quite a bit...maybe post a video of the vehicle running and let some of the guys/gals on this site give it a listen.....I'd be willing to bet there are quite a few mechanics on this site that can give you a pretty strong opinion. Good luck with your 'Taco!!
  3. Dec 2, 2021 at 1:59 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Could you post a recording of the “diesel” sound just to compare? I had the same kind of thing on my new 2018 (sounded like a power stroke I thought) and over time that sound disappeared. Nice and quiet now.
  4. Dec 2, 2021 at 2:02 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    The truck is still breaking in. It should settle down after 10,000 miles.
    wiljayhi likes this.
  5. Dec 2, 2021 at 5:22 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Direct Injected engines tend to be quite noisy compared to Port Injected engines due to the mechanical high pressure pump and the injectors opening and closing under high pressure.
    Manufacturers try to quiet them as much as possible with foam padding around the high pressure fuel system but they still make noise.
    That being said if you post a video clip of your noise I'm sure the members here can tell you if it's normal or not.
    TnShooter likes this.
  6. Dec 2, 2021 at 9:20 PM
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
    lol good luck with all that, it actually is normal for these trucks. It does not quiet down after 10K miles as some have said, I am almost near 70K on mine an it still does it and still just as loud but it doesn't bother me. I had been questioned if my truck was a diesel once, I LOL'd at that too.
    Who are you to say it isn't normal? Being a journeyman mechanic for 30 years doesn't mean squat, just showing your ignorance is all.
    If you bothered to search around on here you would have seen that there is already a lot of threads covering this.
    https://www.tacomaworld.com/threads/engine-tick-at-idle.662323/
    https://www.tacomaworld.com/threads/engine-ticking-noise.567253/
    https://www.tacomaworld.com/threads/is-this-sound-the-taco-tick-everyone-is-referring-to.439788/
    The noise you're referring too is the fuel injector self cleaning cycle that cycles on and off when the truck is idling. So yeah when pulling up an idling in drive-thru's, ATM's etc it will come on and it will be somewhat noisy.
    If you don't like it trade it in for something else. I heard Tesla's are pretty quiet.
  7. Dec 2, 2021 at 9:54 PM
    Bishop84
    Bishop84 Well-Known Member
    I bet the test drive unit was noisy too.
    Enjoy your truck!
