Noisy muffler
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eewoz, Oct 15, 2011.
  1. Oct 15, 2011 at 10:35 AM
    eewoz
    eewoz [OP] Member
    Ed
    Buffalo, NY
    2011 4x4
    I just bought a new 4 cylinder 2011 4 x 4. Awesome truck. I think I'm going to love it. The only issue is the exhaust seems loud to me. I used to drive a 2003 Dakota. With the stock muffler it was very quiet. Replacement mufflers had a little bit of noise associated with them but not as loud as what I am getting with the Tacoma. When I did the test drive I immediately though that it was a little loud but I new Tacoma was what I wanted and just assumed they were on the noisy side. Now that I am driving it more it is becoming annoying. It is not an exhaust leak. The noise definitely coming out the tailpipe. Are Tacoma's normally on the noisy side? Is there only one muffler that comes with new vehicles or is there a high performance exhaust package that may be on the noisy side? I mentioned the noise to the salesman and he indicated that the noise was normal and that it occurred because it was a 4 cylinder engine. It just sounds louder than what I would normally expect. Has anyone had similar impressions?
    Thank you.
    Ed
  2. Oct 15, 2011 at 10:57 AM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    If you were to toss an aftermarket resonator on you would likely be able to cut down a lot of the noise
  3. Oct 15, 2011 at 11:01 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I put a stainless exhaust tip on mine that extends the exhaust a little more beyond the bedsides and seems to eliminate any reverb off the truck.
  4. Oct 15, 2011 at 11:10 AM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    It doesn't... it would be the same as just extending the exhaust pipe. Some vehicles have a tendency to rebound exhaust noises off of the truck, and extending where the exhaust leaves the pipe further away from the truck will help alleviate this issue in many cases. I just don't want people thinking that the exhaust tip itself is alleviating this. The tip is just a tool
  5. Oct 15, 2011 at 3:53 PM
    eewoz
    eewoz [OP] Member
    Ed
    Buffalo, NY
    2011 4x4
    That's what has me wondering if what I have is normal or not. Its just loud enough that it may be what most people prefer. I'm going to look into some of the suggestions given earlier in the thread. I think I am going to want to do something...
  6. Oct 15, 2011 at 3:59 PM
    eewoz
    eewoz [OP] Member
    Ed
    Buffalo, NY
    2011 4x4
    You might be right. The noise level may well be there by design. Me no like though so aftermarket may be the solution.
  7. Oct 15, 2011 at 4:02 PM
    eewoz
    eewoz [OP] Member
    Ed
    Buffalo, NY
    2011 4x4
    The noise may be part of a reverb affect. I see that Advance Auto has some cheapie chrome ones. I may buy one and bolt it on to see if that helps.
  8. Oct 15, 2011 at 4:08 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Tips do change the exhaust tone. Angled cut tips will give a different tone as opposed to a straigtht cut tips.
  9. Oct 15, 2011 at 6:52 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Hmm... You may be right. I am unfamiliar with that. I couldn't imagine the change being too much though
  10. Oct 16, 2011 at 6:33 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I had an exhaust on a 350 V8 (stock SLP with Borla muffler) and hi-flow cat that dipped down and straight out the driver rear (about 6-7 inches off the road) in the airstream and it scavanged the exhaust out of the engine so well it was almost like having a supercharger!
