Noisy Release Bearing Clutch 6 Spd Manual Xrunner recurring FIX
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pdanieljohnson, Jun 23, 2017.
  1. Jun 23, 2017 at 8:58 AM
    pdanieljohnson
    pdanieljohnson [OP] New Member
    I have a 2005 xrunner, clutch noise developed and I brought it in to have clutch replaced and release bearing replaced...the noise did not go away. I read many complaints regarding the 6spd release bearing noise but no viable solutions...
    http://urdusa.com/store/p1260519023...IT,-2005+-Tacoma-V6-6-Speed/product_info.html
    Here is the fix!
    The design of the throw out bearing assembly used on Toyota trucks can cause uneven wear on the aluminum shaft that the throw out bearing rides back and forth on. The release fork can cause side loading of the bearing as it rides back and forth on the shaft and that can cause uneven wear. When this occurs the throw out bearing becomes loose and can rock back and forth, bind and can cause excessive noise. This sleeve repair kit consists of a precision machined 303 grade stainless steel sleeve that is pressed onto the stock aluminum shaft and is anchored with the included set screws. A new bearing that has been modified to fit over the sleeve is included. Special water proof grease is provided to ensure smooth operation of the new bearing on the stainless sleeve.
    DOES YOUR CLUTCH JERK OR CHATTER?
    DOES YOUR PEDAL FEEL ROUGH OR NOTCHY?
    DOES YOUR PEDAL FEEL LIKE IT’S STICKING?
    ARE YOU HAVING TO REPLACE YOUR CLUTCH & / OR RELEASE
    BEARING MORE OFTEN THAN YOU SHOULD?
    THE PROBLEM:
    These are the most common symptoms associated with a damaged or grooved quill on a transmission. It is also referred to as the snout, bearing carrier, or case extension. In most cases it is an integral part of the transmission case & cannot be replaced. The logical solution is to replace the case or the transmission. Both options are expensive & time consuming, neither of which solves the problem permanently.
    THE CAUSE:
    In the operation of the clutch, the release or throw-out bearing slides on the clutch snout or quill, allowing you to engage and dis-engage the clutch mechanism. Due to various reasons the quill becomes grooved over time. If the quill were made of a harder metal than aluminum, this would not be as common. The most common causes are: improper clutch adjustment, defective clutch assemblies, stop & go traffic, keeping your foot on the clutch (commonly referred to as riding the clutch), loss of lubricant, heat, & etc.
    THE EFFECT:
    The effects of these grooves on the clutch operation are catastrophic. They cause: premature clutch disc wear, premature bearing failure (further adding to the problem), sticky &/or jerky pedal travel, rattling clutch forks, transmission damage, etc.
    THE SOLUTION:
    The Transmission Sleeve Kit (TSK) solves this problem by utilizing a sleeve, precission machined out of 303 Stainless steel, which slips over the original quill. This provides a smooth, hard surface for the oversize bearing to slide on. It is anchored with set screws and is removable & re-usable. As in the case of the Subaru, it must be removed in order to allow any transmission repairs.
    THE RESULTS:
    After installing the Tranmission Sleeve Kit (TSK) you have eliminated the problem forever! You will notice a smooth, fluid like, feel to the pedal. Your engagements will be smoother. Your clutch will last longer. This in turn, will reduce the wear on your transmission. It will never groove again!
    THE KIT:
    The kit comes complete with a 303 Stainless steel sleeve, set screws & hex wrench, oversized release bearing, hi-temp grease packet, notification sticker, & instructions. The kit comes with a 1 year, unlimited mileage, warranty.
  2. Jun 23, 2017 at 9:31 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
