Noisy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MachTac, Oct 24, 2014.
  1. Oct 24, 2014 at 11:21 AM
    MachTac
    MachTac [OP] Well-Known Member
    Kody
    MD
    Storm Trooper in boot camp
    2'' Spacer Lift 15% Tint Thrush Turbo Muffler It's All About That Bass STICKERS!
    Don't mind the knocking sound it actually doesn't knock its just the video. However, that high pitch is what I'm asking about. At first i thought it was the belt, but now I'm starting to think its a pulley. Sounds like it's coming from the right side, maybe the middle. Any ideas?
  2. Oct 24, 2014 at 11:00 PM
    MachTac
    Kody
    MD
    Nobody?
  3. Oct 24, 2014 at 11:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sorry, But with out actually being there and hearing or seeing it personally I can't offer much help.
  4. Oct 25, 2014 at 6:32 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you rev the engine, does the noise increase velocity with the engine?
    Theoretically... belts don't make any noises unless they're slipping on the pulley and its a high pitched screaching sound usually at the beginning when you step on the gas.
    It could be a bearing going bad...a bearing inside one of the pulleys. You have to figure out which pulley/bearing is making the noise.
    Sometimes...if you spray a very small amount of light oil (WD, PB, etc) on the bearing from the outside, enough will get inside to 'quiet' the bearing - and hence, you'll know which bearing it is. DO NOT get any oil on the belt or pulley surfaces!!!
  5. Oct 25, 2014 at 2:23 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I can't help from the video.... Need more info. Year, Mileage, etc. Usually, IMO, the first to go is the water pump bearings .... but can't tell .
  6. Oct 26, 2014 at 9:46 AM
    MachTac
    Kody
    MD
    It doesn't change pitch with the rev of the engine. After i run the engine for 15 minutes the noise goes away. 2006 92xxx miles
