Nokian air pressure
Discussion in 'Wheels & Tires' started by montanacruiser, Jan 5, 2022.
  1. Jan 5, 2022 at 2:05 PM
    montanacruiser
    montanacruiser [OP] Well-Known Member
    2017 DCLB Off Road
    Hi all I just got me a pair of Nokians in LT265/75R16 119/116Q and was wondering what a good air pressure would be. The tire shop had them at 40psi and they where definitely over inflated. I would do the chalk test but there is snow everywhere. So if anyone has these what have they had luck with? Double cab long bed with topper.
    Thanks
  2. Jan 5, 2022 at 2:07 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I'd go with whatever your door jam says.
  3. Jan 5, 2022 at 2:13 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    29-30 psi is a good place to start.
    Definitely drop off the 40 psi.
    Check only when the tires have been driven less than 1 mile. I'd say cold tire temperature, but this time of year everything is cold. A "cold" tire means that it has not been driven to build any heat in the sidewalls, tread or air.
    eurowner likes this.
  4. Jan 6, 2022 at 5:40 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    37 is the adjusted recommended psi for that size and load rating.
