Nokya Harness
Discussion in 'Lighting' started by Fern, Jan 12, 2012.
  1. Jan 12, 2012 at 6:22 PM
    Fern
    Fern [OP] TEXAS IS HOT!
    Fernando
    San Antonio,Tx
    '12 SUPERWHITE SPORT 4x4
    285/70R17 COOPER STT PRO | MOTO METAL 957 | 3" 885 COIL LIFT W/ AAL | MAGNAFLOW MUFFLER | AVID OFFROAD LIGHTBAR W/ 22" LED BAR
    I'm looking to getting some yellow nokya bulbs for the fogs, does anyone on here run the plug and play harness for them too? I was debating whether to buy it or not, worried bout melting or damaging the stock harness. Also I noticed for the 2012 owners, the fogs are H11 now, not H10.
  2. Jan 13, 2012 at 7:37 AM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    How many watts are the new bulbs?
  3. Jan 13, 2012 at 10:28 AM
    Fern
    Fernando
    San Antonio,Tx
    55 watt
  4. Jan 13, 2012 at 10:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What's this harness you speak of? I ran the Nokya bulbs and just plugged them into the stock wiring, no additional harness required. :confused:
  5. Jan 13, 2012 at 10:44 AM
    Fern
    Fernando
    San Antonio,Tx
  6. Jan 13, 2012 at 10:47 AM
    Pugga
    Massachusetts
  7. Jan 13, 2012 at 10:50 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    check the bulbs again, mine are 42watt and say 55watt light output. i just plugged them in, no issues so far
  8. Jan 13, 2012 at 11:02 AM
    iroc409
    Washington
    A red one
    Two 55W bulbs are less than 10 amps, and I believe the factory circuit is fused at 15 amps. I wouldn't worry about a wiring harness, you're more at risk of melting the plastic housings than the wires.
    The factory bulbs I think are 27W, at 42W I wouldn't even flinch.
    Unless you're looking at a wiring harness to fight off voltage drop from the factory wiring, but honestly the factory fogs are useless in just about every driving scenario but the very worst, so it's not really an effective use of a wiring harness (better off doing the headlights).
  9. Jan 13, 2012 at 11:05 AM
    iroc409
    Washington
    A red one
    Probably a waste of $20. On high output bulbs, like above factory headlights at 55-60W, it is probably a consideration--but I'd only install ceramic plugs if installing a wiring harness, I wouldn't bother otherwise.
    My headlights are 65/70W and the plugs have held up fine with factory, non-ceramic plugs.
  10. Jan 13, 2012 at 11:10 AM
    Fern
    Fernando
    San Antonio,Tx
    ^^i don't have the bulbs yet so can't confirm what they say. I do however have an H4 nokya bulb that box says 90/100watt and the bulb itself says same thing.
