NoLoss valve caps.
Discussion in 'Product Reviews' started by chris4x4, Jan 26, 2011.
  1. Jan 26, 2011 at 2:58 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Will from Sierra Expeditions set me up with a set of these to try out. Right now, Will is having a TW discount on these here.They are very good quality, and they have a nice, durrable nylon seal inside them. The valve caps are attached to the valve stem via a rubber/plastic lanyard. You thread the open end on the valve stem, and it holds the cap to the stem, preventing loss when airing down, or checking tire pressure as a regular maint. rutine. The va;ve cap itself has a grove cut in it that fits the lanyard, and allows it to rotate smoothly, while still retaining the cap securly. Although these are not recomended for aluminum stems, I have been running aluminum valve caps on my TPMS stems for quite some time without issue. The valve caps I have been running have been submerged multiple times in local lakes, pee'd on by local stray cats, and have never shown signs of coroding to the stems. These seem much more durrable than the ones I have been running. I talked to Will about them being run on TPMS equiped vehicles, and we both agreed that applying a very light amount of an anti sieze is the best way to go. Anyway, They are rated to be able to be able to hold air pressure in the tire, even if the valve core leaks. I have no doubt this would be true, given the seal material.
  2. Feb 21, 2011 at 11:41 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Nifty. Just might have to pick up a set. :cool:
  3. Feb 21, 2011 at 11:43 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    I have them also. They look pretty cool. and now I don't worry about loosing them in the dirt while I air down.
  4. Mar 7, 2011 at 4:59 PM
    FlyingWil
    FlyingWil Well-Known Member Vendor
    Wil
    Sonoran Desert
    01 DC Expedition Ready
    Shrockworks Front Bumper, LightForce 240's, PIAA 510's,T-Max 9000 competition winch with Outback (longer drum) and modified brake wireless controller and Masterpull line with Viking safety thimble, Rugged Ridge Hawse, Daystar Winch isolator, SAW Racerunner 2.5 coilovers, Safari Snorkel, IBS dual battery system with RBM, Scangauge II, Total Vision self spotting kit and monitor with aux output and remote, Low Tek Gauge pod with Cyberdyne gauges for fridge and battery, Yeasu FT-7800 head unit mounted in ceiling linner and speaker Larson Hood mount, Uniden Pro 520XL CB radio in the ash tray location,'lil Wil Mag mount antenna, Odessey 1200 MJT & Die Hard Plat. dual batteries, Can-Back with extra mounts, Blue Sea 12 st Fuse Box, 100 Amp 100 Amp Relay, Extremeaire & 5 Gal air tank w/ 145 psi switch, Custom bed drawer system, Engel Mt-45 with TwoZone, protective covers, and Engel Slide Eezi-Awn 1600 RTT w/ Ikea LED light mod, and sheet set, CBI offroad Expedition rear bumper, jerry can tir
  5. Mar 7, 2011 at 5:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think the Aluminum ones are just fine!
    UPDATE:
    I have had no issues at all with these sticking to the TPMS stems. I only applied a little bit of anti seize at the inital installation of the caps, and have removed them about 2 dozen times. They work great! On another note, No one has stolen them off my truck either! :p
  6. Mar 7, 2011 at 5:25 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Might have to get in on a set.
  7. Mar 7, 2011 at 5:28 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    since i threw all my stock ones away because one almost effed my ass....i may jump also
  8. Mar 7, 2011 at 5:30 PM
    crf69
    Ohio
    ummm yeah
    and they take paypal too :)
    sweet!
  9. Mar 10, 2011 at 6:50 PM
    crf69
    Ohio
    ummm yeah
    :Dpayment sent to sierra expeditons!
