(NON-JBL) Bypass Factory Amplifier for more RMS?
Discussion in 'Audio & Video' started by Key-Rei, Jun 22, 2021.
  1. Jun 22, 2021 at 7:39 PM
    Key-Rei
    Key-Rei [OP] Well-Known Member
    Key
    Florida
    Tried searching for an answer but all threads return JBL results, I don't have the JBL system.
    I do have an aftermarket headunit (KD-R895BTS) which advertises 22w RMS and best result I can find is the factory amp outputs 12w RMS.
    Would negating the factory amplifier drive my speakers I have coming (Rockford Fosgate T1675-S) better?
    If so how do I do that?
    Best place to mount the crossovers for the tweeters where they'll be most protected from potential water intrusion?
  2. Jun 22, 2021 at 8:30 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    If you don’t have the JBL system, you don’t have a factory amp
    In the non JBL system, the radio powers the speakers.
    Take out the radio and replace it, now the new radio powers the speakers
    Hooper89 likes this.
  3. Jun 24, 2021 at 3:57 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    From what I see with minimal searching is that your radio has 3 sets of RCA outputs. Sub, left, and right. Use these to feed an external amp. If you don't want huge amounts of power, you can use the factory wiring for the speakers. Disconnect them from the radio harness and connect them to the amp outputs.
    I believe Alpine makes a 4 channel amp that fits in the dash. That would make life very easy having to only run one wire from the battery to feed the amplifier.
    Key-Rei[OP] likes this.
