Non OEM Camshaft position sensor , 1GRFE
Discussion in 'Technical Chat' started by TacomaGU, Mar 12, 2020.
  1. Mar 12, 2020 at 7:34 AM
    TacomaGU
    TacomaGU [OP] Member
    Guam
    2005 Sliver Tacoma V6 4x4 6 speed double cab, short bed
    Has anyone installed a cheaper non OEM camshaft position sensor on their 1GRFE V6. If so how is your engine running? What brand? Asking for a friend. Upgrading on a budget. Thank's in advance.
  2. Mar 12, 2020 at 11:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Like every thing else it will be hit or miss.
    The real Question Is do you feel lucky.
    It would depend where you friend lives if the truck shutting down might put them in a location where at least on fully automatic weapon might decide things in there favor .
    Are you replacing them both?? Just why has it or they failed??
    I have used the Cheap Napa one @ 42.00 list in a emergency .
    TacomaGU[OP] likes this.
  3. Mar 13, 2020 at 2:44 AM
    TacomaGU
    Guam
    Scanner indicating Bank 1 Camshaft position sensor signal low. pulled sensor, physically damaged, most likely due to heat and old age. 208,000 miles
  4. Mar 13, 2020 at 3:21 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    If going a used one is a option something you can pull yourself and inspect if your going low budget a thought in any case .
    TacomaGU[QUOTED][OP] likes this.
  5. Mar 13, 2020 at 4:11 AM
    TacomaGU
    Guam
    Will consider! Current symptom- hard start about 2-5 tries, But engine runs great and gas mileage is the same. time for a new timing chain kit replacement. original timing chain 208,000 miles.
