Non-skid seatbacks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rob_s, May 5, 2012.
  1. May 5, 2012 at 6:20 AM
    rob_s
    rob_s [OP] Well-Known Member
    SE FL
    White 2010 DC SB Sport
    I've taken to driving around most of the time with the rear seatbacks folded down in my DC. The problem is that they are slicker than shit, and the dog slides around, the laptop bag slides around, etc.
    Anyone do anything to make them non-slip? I was thinking of getting the roll-on bedliner but I'm not sure if they dry hard or slightly rubbery. I need something that will stand up to the dog's nails and other stuff.
  2. May 5, 2012 at 6:22 AM
    Grundletaint
    Grundletaint Well-Known Member
    Austin
    2012 crewmax tundra 4x4
    Debadged, derped, weathertech visors, antennax, tinted, need more money
    I stick one of those thick mexican blankets over it and tuck it under the folded seats so it doesn't move around. Works great and I can wash it. Also a nice cushion for the dawgs.
  3. May 5, 2012 at 6:38 AM
    rob_s
    SE FL
    I should add that the other thing(s) that slide around back there are the gun cases and range boxes. I'm really looking for something I can coat the plastic with and have it just always be there when I drop the seat.
  4. May 5, 2012 at 6:51 AM
    Barbaro
    Barbaro Active Member
    06 PreRunner DCSB Indigo
    I have always wanted to get some of this stuff. SeaDek. You could get them to custom cut some sheet that would fit that back of the seats.
    www.seadek.com
  5. May 5, 2012 at 7:25 AM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    I want to F*ck the hell out of that sig.
  6. May 5, 2012 at 9:12 AM
    rob_s
    SE FL
    That's not a bad idea, and we have so many boat stores down here it shouldn't be hard to find a local source.
    I'm kind of set on having a brush-on type finish though because the seatback isn't flat.
    (not my picture)
  7. May 5, 2012 at 9:18 AM
    rob_s
    SE FL
  8. May 5, 2012 at 9:20 AM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails WANT: Rear Plate Bumper, RokBlokz mud flaps, Steel bed cage
  9. May 5, 2012 at 9:57 AM
    rob_s
    SE FL
    thanks!
    back to the drawing board...
  10. May 5, 2012 at 10:00 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    x2 :D
  11. May 17, 2014 at 10:44 AM
    rob_s
    SE FL
    Well, two years later is finally got the SeaDek cut and installed. One 18x38 sheet covered this all with a little bit to spare.
  12. May 17, 2014 at 1:07 PM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    :thumbsup:
  13. May 17, 2014 at 4:41 PM
    deadbird8
    deadbird8 Well-Known Member
    Dallas, TX
    14 4x4
    I posted this on another thread today, another option is Hydro Turf- they use for covering PWC and boat floors for traction and sound dampening. It comes in Grey and Black, smooth, diamond cut, waffle cut, and lined. Its closed cell foam and can be cut easily to any pattern. You can apply with 3M Super 90 or contact cement if you don't get the Peal and Stick option.
    http://hydroturf.com/add_to_cart.php?cat=Sheets+of+Hydro-Turf&num=SHT40CG
    http://hydroturf.com/add_to_cart.php?cat=Sheets+of+Hydro-Turf&num=SHT86CG
    They also have close out sheets which are less expensive.
    http://hydroturf.com/products/Closeouts_and_Specials/Sheets_of_Turf
  14. May 17, 2014 at 4:48 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Wow... Thanks for bumping the thread.
    I could really use this stuff in my bathtub!
