Non-spec 2024 Tacoma's being delivered, be very careful
Discussion in '4th Gen. Tacomas (2024+)' started by DRB777, Feb 25, 2024.
  1. Apr 5, 2024 at 4:01 PM
    #241
    W00die
    W00die Member
    Scott
    Hampton Raods, VA
    Gen 4 Tacoma SR5 - Underground
    Right off the showroom floor. Mods incoming
    Not sure whether this is water under the bridge or not, but I thought I'd post an update. I just picked up my SR5 this morning. The spare is one of the first things I checked. On my truck, I received a full size, NON Temp spare. It's the real deal. For what it's worth...
  2. Apr 5, 2024 at 5:22 PM
    #242
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Awesome.
    Now drop it and flip it over so you can check the air pressure on it without having to drop it in the future lol.
    Steves104x4 and Otterstuff like this.
  3. Apr 5, 2024 at 5:27 PM
    #243
    W00die
    W00die Member
    Scott
    Hampton Raods, VA
    Dropping it to check pressure is trivial IMO. Regardless of that, it will be removed and stored with the OEM wheels/tires as soon as replacements are installed so I'm not particularly concerned about it. LOL
  4. Apr 5, 2024 at 5:42 PM
    #244
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    What region are you in?
  5. Apr 5, 2024 at 5:54 PM
    #245
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    BB gun legal in your area? Or Aquila Quiets?
    I have a barn/outside cat keping squirel polulation down, but sometimes he needs help.
  6. Apr 5, 2024 at 6:17 PM
    #246
    W00die
    W00die Member
    Scott
    Hampton Raods, VA
    S.E. Virginia. The truck came out of the Veracruz (Guanajuato factory) and shipped to Newark where it spent a month in the QC hold, and finally made it to the dealer in Virginia Beach earlier this week.
  7. Apr 5, 2024 at 8:50 PM
    #247
    DRB777
    DRB777 [OP] Well-Known Member
    David
    2024 Tacoma SR5 4X4 double cab
    None so far
    Excellent, I'd like to think the stink I caused made a difference. Recently, I've heard some say it makes a difference which upgrade package(s) each SR5 has. But Toyota & their distributors have been unresponsive about such details, so there may not be a definitive answer.
    BTW, here's a pic of my "early" '24 SR5. ('Been away from this forum as the mod chose to excile me.) And the front air dam has been removed.
    Lt. Dangle and Steves104x4 like this.
  8. Apr 5, 2024 at 8:59 PM
    #248
    DRB777
    David
    None so far
    During my rodent damage ordeal, I learned about the transmission lock-up override switch. Since most all of this forum's members probably already know about this "secrete & hidden" feature. I spare the details unless anyone needs to know. But be aware that under certain conditions, the auto transmission can lockup in park, even when the engine still starts and runs.
  9. Apr 6, 2024 at 10:49 AM
    #249
    DRB777
    David
    None so far
    'Can't tell from your picture, is the spare wheel alloy or steel? Thanks W00die
  10. Apr 6, 2024 at 11:07 AM
    #250
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    the full size spare wheel on my 3rd gen is stamped with “temporary use”.
    Barsoom likes this.
  11. Apr 6, 2024 at 11:09 AM
    #251
    mosccat
    Mark
    2020 OR
    I bet if you take the wheel out and look on the outer side of the wheel there’s a decal saying “temporary use only”.
    Barsoom likes this.
  12. Apr 6, 2024 at 12:03 PM
    #252
    DRB777
    David
    None so far
    My gen2 '12 TRD OR had that sticker on the steel spare wheel. 'Replaced the tire, not sure if that makes it non-temporary or not. I think anything that makes a spare different than the other 4, gets the sticker. (tire or wheel)
  13. Apr 6, 2024 at 12:06 PM
    #253
    Bishop84
    Bishop84 Well-Known Member
    The reason its "temporary' is because of the lug nuts. They are able to secure steel rims but are not intended to be used full time.
    The chamfer wears quickly on them and the washer rattles around.
    All full sized tires are speed rated for the vehicle properly. Only space savers have speed rating limits.
  14. Apr 6, 2024 at 12:14 PM
    #254
    DRB777
    David
    None so far
    Yes but "full sized" now has a new definition. (spot-on correct though) Another reason I don't like it when they cheapen-out on the spare.
    Vitamins likes this.
  15. Apr 6, 2024 at 12:48 PM
    #255
    W00die
    W00die Member
    Scott
    Hampton Raods, VA
    I checked. It does.
  16. Apr 6, 2024 at 12:49 PM
    #256
    W00die
    W00die Member
    Scott
    Hampton Raods, VA
    It's steel. So, yes, as others have mentioned - the wheel itself is Temp Use only.
    DRB777[QUOTED][OP] likes this.
  17. Apr 6, 2024 at 6:00 PM
    #257
    Barsoom
    NW GA OTP
    Same on my 22.
    I want to pick up a matching rim for my Sport rims and do a 5 tire rotation.
  18. Apr 6, 2024 at 7:30 PM
    #258
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    What would you do about the tire pressure monitor?
  19. Apr 6, 2024 at 7:40 PM
    #259
    DRB777
    David
    None so far
    Barsoom[QUOTED] likes this.
  20. Apr 6, 2024 at 8:28 PM
    #260
    Barsoom
    NW GA OTP
    Have not thought that far yet.
    shakerhood[QUOTED] likes this.
