Non Tacoma Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2021SR5V64WD, Jul 6, 2025 at 12:22 PM.
  1. Jul 6, 2025 at 12:22 PM
    2021SR5V64WD
    2021SR5V64WD [OP] Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Wife drives a 2017 Forester. Good passenger car. 55,000 trouble free miles.
    Took it to independent shop for 60k service.
    They advised that the transmission cooler we had installed when new, to assist when towing a small camper in Arizona weather was 'leaking' just a little. Advised they could remove it and i'm like no don't remove it.
    There has never been and 'drip' on the driveway. Not one drop in 8 years. There has never been any warning light. I would have never known if they didn't say anything. Since there is no dipstick to check the levels, which I think is stupid, is this a potential issue?
    I might take it back to the shop that installed it to check it out but should it be of major concern, seeing that there is not a 'drop' on the driveway?
    I would have posted to the Subaru Forum but they banned me for life LOL.
    Williston, OZ TRD, kahanabob and 4 others like this.
  2. Jul 6, 2025 at 12:24 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
  3. Jul 6, 2025 at 12:26 PM
    SACTOWN
    Greg
    Banned you for LIFE?!!?!?!? What forum
  4. Jul 6, 2025 at 12:29 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Can you take a look to see if it is indeed leaking? Congrats on being banned from the LL bean forum too!
    Curveball30, SR-71A and SACTOWN like this.
  5. Jul 6, 2025 at 12:31 PM
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    I second opinion never hurts. I have a 2004 Honda Element that I brought in for some service a few months ago. They said I had an oil leak. Similar, no drops in driveway WTF they talking about. I had them show me where it was leaking and they were right. It was a slow leak, just never hit the ground.
    SACTOWN likes this.
  6. Jul 6, 2025 at 12:48 PM
    2021SR5V64WD
    Subaru Forester forum. They put out a global message that anyone using the word ( starts with 'T' ends with 'FF' ) would be banned.
    So I posted about 20 lines of the word over and over again.
    Boooom - banned.
    SACTOWN[QUOTED] and Taco_mike73 like this.
  7. Jul 6, 2025 at 12:51 PM
    2021SR5V64WD
    I suppose I could crawl under. Getting down on the ground and scooting in is one thing, scooting out and getting back on my feet
    at damn near 70 years of age is another. Plus the pavement is about 140 degrees to boot.
    No idea why these auto's don't have a dip-stick to check levels. I suppose in a few years there will be no dipstick to check the oil as well.
    OZ TRD likes this.
  8. Jul 6, 2025 at 12:57 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    How long do you plan on keeping the 2017 Forester? If a long time might not hurt to get the leak addressed.
    If you might sell/trade it soon, then I would just monitor the fluid level. I imagine the check level procedure is similar to that of our Tacomas.
  9. Jul 6, 2025 at 1:00 PM
    I-Give-Up
    I-Give-Up Well-Known Member
    West Phoenix, AZ
    2023 Ice Cap Tacoma TRD
    Meso spare fuse holder. Aluminum gas cap holder. Genuine Toyota bed lights. Bed molle racks. Ammo case storage under hood. In-bed spare tire. Automatic underhood lights. Gooey glurp on frame.
    Yes. Take it back to the place that installed it. (I'm a former owner of a 2017 Outback which is mechanically similar.) It is possible to get leaks under pressure, slight though that pressure might be thru the cooler, that may not appear as drips on your driveway.
    Unless the transmission cooler is actually defective, or if the hose clamps are loose, I think that the place that said it is leaking may be wrong. Did they even check the level of the transmission fluid? That is not simple to do, and no conclusions can be made without a fluid level check. (A Subaru CVT fluid level check is similar to the level check on my 2023 Tacoma.)
    Do you want the CVT on your Forester to last 300,000 miles? If you do, take it to a good shop that understands Subarus with CVTs. Ask them to do a remove plug, drain, and refill on your CVT. That will change out about 3 quarts of CVT fluid out of maybe 8 total quarts. Use only actual Subaru CVT fluid! Do this every 30,000 miles. Dealers do not like to do that because they think it can get them crosswise with Subaru's CVT warranty and will tell you that the CVT transmission uses a lifetime fluid. As an Arizonan, I believe that to be horse pucky.
    I can't recommend a good shop, sadly. I did my own work.
    RustyGreen likes this.
  10. Jul 6, 2025 at 1:04 PM
    SACTOWN
    Greg
    :eek:
    soundman98 likes this.
  11. Jul 6, 2025 at 1:07 PM
    MGMDesertTaco
    TaRiFf? Tariff? TARIFF? that one?
    edit: more tariffs! :p
  12. Jul 6, 2025 at 1:54 PM
    TA2016
    Oregon
  13. Jul 6, 2025 at 3:35 PM
    2021SR5V64WD
    Oh yea the 60k service changed the tran and cvt fluid and spark plugs and what-nots.
    I used a real good independent shop. The shop that put the cooler in ONLY works on Subaru but they were booked for the week I had
    time to get there so I used my Taco- dudes who had a Subi guy on board. The Subi Shop I use in Tempe is Subiworks... if you're nearby and
    need something done I highly suggest seeing these folks - same crew for 8 years that tells you something.
    For the taco I go to YotaPros in Tempe they are darn good too.
  14. Jul 6, 2025 at 4:26 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    what’s wrong with Tuff?
  15. Jul 6, 2025 at 4:33 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Road_Warrior, SR-71A and AvalonTaco like this.
  16. Jul 6, 2025 at 5:05 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    First of all, you should be banned here for posting this in the 3rd gen section instead of https://www.tacomaworld.com/forums/general-automotive.57/ :wink:
    Secondly, Subarus leak by nature. All the OEM spring clamps sag with age and leak. So you will need to jack up the vehicle and have a look, both at your ATF cooler and all the OEM hose connections.
    Williston and kahanabob like this.
  17. Jul 6, 2025 at 8:44 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i really wouldn't worry about it. i think it's a good idea to address the leak if you can(cracked hose, or bad clamp?), but it would take a rather large puddle under the car before the level is effected to any significance.
    my old chrysler lebaron taught me that the transmission needs to be about 2-3 quarts low to effect much, and the main condition will be a lack of shifting, where it just holds 1st, if it goes into gear at all.
  18. Jul 6, 2025 at 9:17 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
  19. Jul 6, 2025 at 10:05 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    They want to remove the cooler because if the "little" leak turns into a "big" leak soon amd they were the last ones to touch it by doing a drain and fill then they could be liable for transmission damage. I'd bring it up too..
    If you don't trust them then crawl under and look for yourself. It would take about as much time as posting a thread on the internet
    Or take it to a different shop
    Dripping or not, a leak is a leak and they're right to bring it to your attention.
  20. Jul 6, 2025 at 10:09 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Spring clamps don't lose tension, usually it's the rubber getting flat and compressed under the clamp that makes the hose connection loosen up. Thats why you can always move the spring to a different position on the hose and it'll go back to squeezing better.
    Sure the super small ones can get bent if you aren't careful with the pliers but if you dont mangle them they can be re-used for a long time
    Worm clamps are the ones that can back off over time
