Non Tacoma ???
Discussion in 'General Automotive' started by Maint1, Nov 4, 2021.
  1. Nov 4, 2021 at 9:52 PM
    Maint1
    Maint1 [OP] Well-Known Member
    NC
    2019 DCLB Quicksand
    17" matte black 4Runner rims
    I have a 2010 corolla that the wipers will not work on low. They work fine on high other than stopping where ever when the arm is cut off. I ordered a variable speed arm but same problem.
    My question would be is there a relay? I looked in the box under the hood. Or could the motor have problems? Any help would be appreciated!
  2. Nov 4, 2021 at 9:58 PM
    Bishop84
    Bishop84 Well-Known Member
    The primary relay is inside the wiper stalk control. There's 2 fuses but if either blew, you'd have zero wiper operation, so they are good.
    There is a separate circuit inside the motor that can fail. Basically its a resistor that slows down the speed of the wiper.
    So either a wiring issue, unlikely.
    Or a wiper motor.
    TnShooter likes this.
  3. Nov 4, 2021 at 10:25 PM
    Maint1
    NC
    2019 DCLB Quicksand
    Thank you. The switch arm I ordered was used, but surely it wouldn't be bad as well. I will look into the motor. When low speed and intermit. went out, they started dragging before finally going out.
