non-TRD diff-lock switch blank
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jay W., Mar 3, 2010.
  1. Mar 3, 2010 at 9:58 AM
    Jay W.
    Jay W. [OP] Whaaat?
    Jay
    Central, SC
    06 Tacoma DoubleCab SR5 4x4
    Hey fellows..
    I've searched several different things trying to find this, and can't..however if someone can point me in the right direction I'd highly appreciate it!
    I'm fixing to add a switch for some extra lights in my truck, and I was looking at the little square where the diff-lock switch should be. Does it pop-out or will i have to take apart the whole dash to remove it?
    thanks,
    -Jay
  2. Mar 3, 2010 at 10:00 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Gently pry out the space-holder with a thin knife/screw driver. If you work both top and bottom, it should come right out.
  3. Mar 3, 2010 at 2:00 PM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    if you can reach up under the dash, just push it out from the back. If not, the screwdriver method should work, just put some electrical type around your screwdriver so it won't scratch your dash.
  4. Mar 3, 2010 at 6:16 PM
    Jay W.
    Jay W. [OP] Whaaat?
    Jay
    Central, SC
    Exactly what I was looking for!
    thanks!
