Non TRD to TRD Axle Swap With eLocker
Discussion in '1st Gen. Tacomas (1995-2004)' started by Snowman, Dec 20, 2011.
  1. Dec 20, 2011 at 9:00 PM
    Snowman
    Snowman [OP] I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I have searched and searched here and ttora and google but still have a few questions.
    I have a 4cyl AT with 4.56 gears (B04A code)
    I found two complete axles with TRD lockers at a local scrap yard one is 4.10 and the other is 4.30.
    Now to the questions:
    1. Can I regear either of them to 4.56 to match the front of my truck or would I have to match the front to either the 4.10 or 4.30?
    2. Which would be a good choice for a 4cyl auto on 33" tires: 4.10, 4.30 or my 4.56?
    3. They are also listed as 4cyl/6cyl, AT/MT, 4x2/4x4, db/xtra/reg cab, etc, etc does any of that matter?
    4. Would anything else be required to do this swap besides the axle, control box and switch?
    Thanks
  2. Dec 20, 2011 at 9:02 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Why not just put an ARB in? The 8.4" axle (that you have right now) is stronger than the TRD 8"
  3. Dec 20, 2011 at 9:05 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    ARB would end up running me $1500+ depending on what else I need, the axle swap would be closer to $700-900
  4. Dec 20, 2011 at 9:10 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Yeah. Deff go ARB.
  5. Dec 20, 2011 at 9:17 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Alright, that isnt really helpful. I looked into ARB and it it way too expensive, ARB is stuff is almost double the cost in Canada compared to the States or shipping is deadly, if it can be acquired at all. If I have issues with an ARB install there are no shops around that install them so knowledge is nonexistant.
    So to sum up, I dont want an ARB locker.
    99toytacotrd likes this.
  6. Dec 20, 2011 at 9:20 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Regear the rear to 4.56, it'll be easier then having to tear out the front. Your 4cyl will handle 33s much better at that ratio then at the lower ones. In fact if you can, it wouldn't be bad to go up to 4.88s but that would require two new sets of gears so 4.56s will be fine.
    Make sure the locker motor is in good condition. and as for the names, i think they should all be the same if they are lockers and off a tacoma.
  7. Dec 20, 2011 at 9:20 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    1) Yes, regear the rear axle to 4.56
    2) Bigge the better. Def would go 4.56
    3) No
    4) :notsure:
  8. Dec 20, 2011 at 9:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    sure you just gotta buy the gears. Can go to 5.29s if ya want lol
    in short, rear gear the rear.
  9. Dec 20, 2011 at 9:23 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    They don't come from the factory with 4.56, but yes you can regear them to 4.56 with aftermarket parts.
    I have a TRD and regeared mine to 4.56.
  10. Dec 20, 2011 at 9:24 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Alright awesome.
    Thanks guys
  11. Dec 20, 2011 at 10:46 PM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    Hey this will be sick. I want to do the same thing one day.
    Good luck and keep us posted.
  12. Feb 5, 2012 at 1:25 AM
    SchmitzM1
    SchmitzM1 Project: Shaniqua-Rise of the Purple Taco
    Michael
    Ventura
    '96 5Lug 2.4 5M/T
    Detroit Trutrac rear LSD, K&N Drop In, Deck Plate, Optima Yellowtop, Kenwood Excelon Receiver, Kenwood Excelon mids and tweeters, JL Audio 10" W2 boxed sub behind bench seat, MPL Jackhammer 800w amp, 30%window tints driver and passenger, double layer limo tint across back, double layer limo sun stripe across top 5" of windshield, Custom duct tape seat repair lol,
    Thread hijack.
    Same question, but '96 2WD 5Lug.
    It's been almost impossible to find an an axle locally, but WHICH axle would I be looking for? The 2nd gen trd is wider. The locking 1st gen axle has different mounts for the ubolts (overaxle vs underaxle). And I have heard mixed reviews about swapping the rear axle from a 4runner. and I dont know what the swappability is between the model years and how hard it would be wiring, obviously. but as far as the actual bolting patterns and mounting. Please help. I've posted this question in quite a few threads with no good response. I know you crazy yota gurus are out there......
    Whitetaco94 likes this.
  13. Nov 8, 2017 at 8:41 AM
    KevinC
    KevinC Well-Known Member
    Kevin
    2017 SR5 Quicksand Tacoma
    Out of curiosity, did you ever get this done?
  14. Nov 8, 2017 at 11:37 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Nope. Too much work and expense. Went with a truetrac. Way way cheaper, fairly easy to install and *nearly* as good as the elocker.
  15. Nov 8, 2017 at 1:21 PM
    Taco crazy
    Taco crazy Well-Known Member
    Chattanooga TN
    '97 Tacoma std cab V-6
    Locked front and rear, bumpers, sliders, cage etc..33" Cooper STT PRO's. Mild suspension lift.
    4.56 at a minimum, in fact with a 4cyl I'd run 4.88's no question.
  16. Nov 8, 2017 at 7:02 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    How much did you pay for the TrueTrac setup?
  17. Nov 8, 2017 at 8:17 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Been a few years now, don’t remember exactly but around $500 and I installed it. Got it from summit
  18. Nov 8, 2017 at 9:19 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    I've had two elockers fail on me. I'd say mechanical is an advantage.
    Snowman[QUOTED][OP] likes this.
  19. Nov 9, 2017 at 12:36 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I cant speak on oem elocker quality because I never had one but the TrueTrac is solid, and silent. Only disadvantage is that it isnt completely selectable.
