None of my windows are working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mudrucker, Apr 9, 2021.
  1. Apr 9, 2021 at 6:58 AM
    Mudrucker
    Mudrucker [OP] Active Member
    Kyle
    DFW TX
    2017 SR5
    The 7.5 one or the 10a one?
  2. Apr 9, 2021 at 7:07 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    When mine quit it was the 7.5 one
  3. Apr 9, 2021 at 7:08 AM
    Mudrucker
    Kyle
    DFW TX
    2017 SR5
    If you don’t mind me asking what made yours go out, and where there any other problems other than the window?
  4. Apr 9, 2021 at 7:17 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Check both.
    FWIW, I only have a Gen2 Wire diagram for the power windows. If the 3rd Gen is similar wiring, there is a 30A fuse powering the Power Window Master Switch. This switch is common to ALL windows.
    There is a 50A fuse from the Battery that runs power through a relay to the 30A fuse for the Power Window Master Switch.
    The 7.5A, 20A and the 10A (IG2) run power into the Body ECU. It looks like the 7.5A handles the Courtesy Lights, the 20A handles the Door Locks and the 10A (IG2) powers the relay that is switching the power from the 50A to the Power Window Master Switch.
    So, when you open the door do the Courtesy Lights illuminate? If so, then the 7.5A is good.
    Do the Door Locks function? If so, then the 20A is good.
    This narrows the search to the 10A, the 30A, the 50A or the Power Window Master Switch.
  5. Apr 9, 2021 at 7:52 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  6. Apr 9, 2021 at 9:10 AM
    Mudrucker
    Kyle
    DFW TX
    2017 SR5
    UPDATE:
    There are 3 yellow fuses on the left that give me no signal with a test light. Upon inspection, the fuses looked fine to me. I bet there’s a harness that came unplugged.
    Kev250R and OnHartung'sRoad like this.
  7. Apr 9, 2021 at 9:14 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Was the key on? Those could be switched fuses.
    When mine shit the bed I was poking around behind the head unit :oops:
  8. Apr 9, 2021 at 9:22 AM
    Mudrucker
    Kyle
    DFW TX
    2017 SR5
    the 7.5 fuse tested fine. I was down there installing a remote start so I must have unplugged something. :/
    Kev250R likes this.
  9. Apr 9, 2021 at 9:26 AM
    robe689
    robe689 Well-Known Member
    Bob
    SE Connecticut
    2020 Silver Tacoma SR5 Access Cab V6 4WD
    I've posted this before, but here it is again for the benefit of new members to Tacoma World:
    The Tacoma World "Friday Thread" appears to be a phenomenon whereby an OP (Original Poster) asks a question at some point during a Friday (and it has to be on a Friday to be a true Friday Thread) and the question gets answered (sometimes over and over and over...). Whereupon, the thread then tends to digress from the originally asked question and can take some interesting directions. Occasionally, Friday Threads have been known to start earlier in the week, but these are not truly Friday Threads. Friday Threads are usually fun to follow for a day or two.
    Here is a good example of a Tacoma World Friday thread from March 2019:
    https://www.tacomaworld.com/threads/rear-differential-major-damage.596261/
    Steves104x4 and Malibu7tss like this.
  10. Apr 9, 2021 at 11:15 AM
    Mudrucker
    Kyle
    DFW TX
    2017 SR5
    Update: checked the wiring area and everything looks to be plugged in. Fuses are not coming back with a test light so I’m going to try changing them. The fuses look to be fine tho so I would be surprised if that was it.
  11. Apr 9, 2021 at 12:11 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    Try checking continuity across the fuse(s) using a Meter instead of a test light.
  12. Apr 9, 2021 at 1:23 PM
    Mudrucker
    Kyle
    DFW TX
    2017 SR5
    Well guys I have officially tried everything that I know. There are 3 yellow fuses in my fuse box that are coming back with no test light however I just changed them and still no windows.
    I installed a remote starter on my truck last night and the windows worked prior to installing it. (Start x 2017 Tacoma with H key). All I can think to do is uninstall the remote start and see if that fixes it.
  13. Apr 9, 2021 at 1:27 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Oh shit. I Friday'ed this thread without really helping.
    This can be a wizard level trick. Try pulling both battery terminals (negative off first and on last) and touch them together (Yeah, I left that door open) for about 10sec. That might, or might not, help.
    Kev250R and tclavell like this.
  14. Apr 9, 2021 at 1:57 PM
    5465
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    This and make sure they are removed before testing. Should be quite simple to verify if they are bad.
    Kev250R[QUOTED] likes this.
  15. Apr 9, 2021 at 2:13 PM
    #35
    caribe makaira
    Caribbean, Puerto Rico
    Maybe this:
  16. Apr 9, 2021 at 2:14 PM
    #36
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Told you so
    jimmerheck and skiploder like this.
  17. Apr 9, 2021 at 2:24 PM
    #37
    Kev250R
    Kevin
    Orange, So.Cal.
    Going-forward I suggest you mention things like this in the beginning of your thread asking for help rather than waiting until Page 2 to bring it up. Probably worth noting which aftermarket remote starter you tried to install as there are some vendors here who may be able to help if they know what system you’re talking about :rolleyes:
    Oh and buy a Meter. Way more useful then a test light :D
    This may not have started out as a Friday thread, but I have faith that it can get there! :thumbsup:
    skiploder, mtip, 5465 and 1 other person like this.
  18. Apr 9, 2021 at 2:39 PM
    #38
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    South main auto would like to have a word with you. Hes fond of his scope on the rope you could say.
  19. Apr 9, 2021 at 4:17 PM
    #39
    Kev250R
    Kevin
    Orange, So.Cal.
    I'm a licensed Electrician; a Meter is my most-often used tool because even a cheapie HF Meter can tell me way more then a test light can. Classic (automotive example since we're talking about cars here) was yesterday I was working on a project vehicle I'm re-building. Four wires coming from the ignition, nothing is labeled, multiple spliced wires, etc. Using a Meter I quickly determined that key-on one of them has +12V, two are dead and one had 9.5VDC on it. Spun the dial around on my Meter and two seconds later I'm checking continuity on my grounds, later I used that same Meter to check some fuses and to ID more un-labeled wires. Quick, easy, accurate. Maybe I ought to start a YouTube Channel to explain it :rolleyes:
    SK808, MadKatt and bulalo like this.
  20. Apr 9, 2021 at 4:29 PM
    #40
    Mudrucker
    Kyle
    DFW TX
    2017 SR5
    I need to learn how to use one of these. Lol.
    RedWings44 likes this.
