noob alert - Any advantage of bigger tires on stock suspension?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MIDTNTACO, Jun 13, 2021.
  1. Jun 13, 2021 at 3:52 PM
    MIDTNTACO
    MIDTNTACO [OP] Well-Known Member
    Middle Tennessee
    2020 Midnight Black TRD Sport 4x4 DCSB
    Other than looks, is there any advantage to putting a size up on stock wheels and suspension?
  2. Jun 13, 2021 at 3:53 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Looks
  3. Jun 13, 2021 at 3:56 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Ground clearance, although minute.
    allenn and Junkhead like this.
  4. Jun 13, 2021 at 3:56 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    A little more ground clearance, but only about an inch without a lift.
    Junkhead likes this.
  5. Jun 13, 2021 at 3:57 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Any increase in tire diameter gives you the following benefits:
    -Additional ground clearance.
    -Ability to air down tires further, without losing too much clearance or risking damage to the wheels.
    -Additional traction from a wider and longer footprint.
    -Smoother ride over road imperfections, as the angle-of-attack on the tread face is reduced.
    Junkhead, WiscoPat and charliehex like this.
  6. Jun 13, 2021 at 3:58 PM
    MIDTNTACO
    Middle Tennessee
    I'm not convinced of this.. some setups look amazing, some look like lack of clearance...
  7. Jun 13, 2021 at 3:59 PM
    MIDTNTACO
    Middle Tennessee
    Thanks! Great points.
  8. Jun 13, 2021 at 4:01 PM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    Primary reasons are for increased ground clearance and a better ability to air down when off road. Though a taller suspension will lift the body of the truck, the measurement from the ground to the lowest point of the vehicle (which is the rear diff on Tacomas) can only be increased through larger tires.
    Will most people need this? No. But, if you plan on going beyond your average gravel road or forest service road, it can be a big help, depending on terrain.
    On stock wheels and suspension, there are essentially two options that don't require further modifications - going up one size from factory, which equates to about a 31.5 inch tire, or going to a skinner (but taller) 33 inch tire. Tons of threads on this specifically.
  9. Jun 13, 2021 at 4:02 PM
    WiscoPat
    Pat
    Wisconsin
    Mall Rated
    Beat me to it!
  10. Jun 13, 2021 at 4:06 PM
    MIDTNTACO
    Middle Tennessee
    Thanks, I'll dig around for the 33" on stock threads.
    WiscoPat[QUOTED] likes this.
  11. Jun 13, 2021 at 4:08 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You can only fit pizza cutters if you want 33s. Otherwise it’s gonna be either 265/75/16 or 265/70/17, so 31.6”
  12. Jun 13, 2021 at 4:11 PM
    SRBenjamin
    Benny
    I run 235/85/16, and they cut pizza.:thumbsup:
  13. Jun 13, 2021 at 4:12 PM
    MIDTNTACO
    Middle Tennessee
    I'm leaning towards 265/75/16 (Wildpeaks) (requires I buy 16" wheels).. but also contemplating keeping the stock sport wheels and just wrapping Wildpeaks stock size (265/65/17) on them. 70's look a little cramped to me on some setups. It's good to get some perspective on any additional benefits on upsizing..
  14. Jun 13, 2021 at 4:20 PM
    Shellshock
    Iowa
    Some say looks. Some say ground clearance (as if 1/2” matters in the real world).
    mostly you’ll just spend more money in fuel
    MIDTNTACO[OP] likes this.
  15. Jun 13, 2021 at 4:32 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Cost.
    A 265/75/16 is as big as you can go and keep everything stock. That is about 1" taller and the same width as factory 265/70/16, but virtually every tire I look at costs less in 265/75/16.
    If you have 17" wheels a 265/70/17 is virtually the same diameter and width as 265/75/16. I haven't priced 17" tires. My Tacoma has 16" wheels, my F150 18".
  16. Jun 13, 2021 at 5:04 PM
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    will hurt gear ratio, if an auto it will make an already undergeard truck with an uncivilized transmission even more uncivilized.
  17. Jun 13, 2021 at 5:11 PM
    2020_TRD_OR
    2020_TRD_OR Well-Known Member
    Pennsylvania
    2020 Cement Tacoma TRD Off Road
    Bilstein 6100s & 5160s Wheeler's Super Bump Stops Wheeler's AAL SPC UCAs Sway Bar Relocation Kit RCI Front Skid Plate
    255/85 r16 - take front mud flaps off if you're going to be crunching the suspension with the wheel turned.
  18. Jun 13, 2021 at 5:14 PM
    MIDTNTACO
    Middle Tennessee
    Damn.. this is worth consideration. Thanks!
  19. Jun 13, 2021 at 5:20 PM
    tguil
    tguil Well-Known Member
    Nebraska
    2018 Double Cab TRD Sport 4X4 AT
    For any light off road, travel on forest roads or gravel roads, just get a set of good stock size all terrain tires. I put stock size Michelin AT2s on my 2018 Sport and they most certainly get the job done and they are good for at least 50,000 miles.
    hiPSI, MIDTNTACO[OP] and Junkhead like this.
  20. Jun 13, 2021 at 5:52 PM
    Magoo0134
    Magoo0134 New Member
    2018 Orange TRD Offroad
    I replaced my stock tires with 265/75/16 KO2s, and they were about $30 less expensive each than the 70s. Could be just a local thing, but at the time I theorized that they were more expensive because they were more popular, being the stock tire size.
    Note that I've been wrong before though.
