Noob here with a few questions.
Discussion in 'New Members' started by Prometheus721, Jan 16, 2014.
  1. Jan 16, 2014 at 2:47 PM
    Prometheus721
    Prometheus721 [OP] Member
    I'm new here and I have a few questions that I couldn't quite find answers to searching the existing threads.
    I drive a 2011 Tacoma TRD Sport Double Cab, Short Bed.
    First, the hood scoop. Usually when I'm driving in windy conditions I hear a squealing/howling sound that seems to come from the hood scoop or the wiper blades. Has anybody else experienced this? I used to have an '08 Tacoma w/out the hood scoop and never heard this noise, which leads me to believe it is coming from the hood scoop. Am I just being sensitive to the normal air flow around/over the scoop? Or should I get this checked out? Thoughts/suggestions?
    Second, the Air Circulation button. This seems to be happening more recently since the cold weather and I've been using the heater. I usually have the settings as follows: Air Circulation On, A/C Off, set for Foot and Defrost Vents, Low Flow (not Off), Heat set anywhere from warm (knob straight up and down) to Hottest. If I have those settings and run a little while, the Air Circulation light goes out after a minute or two, meaning circulation is not happening anymore. I can turn it On again, but it will go out in another minute or two, and usually repeat this process my whole commute (~1 hr). Why is that happening? Is it supposed to happen or shouldn't it stay On? This did not happen in my '08 Tacoma. In that truck, if I put Air Circ. On, it stayed on, even after restarting the truck. On this 2011, the Air Circ. goes out all the time. Thoughts/suggestions?
  2. Jan 16, 2014 at 2:49 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Press and hold the circulation button for about 3 to 5 seconds. This will keep it on.
  3. Jan 16, 2014 at 2:53 PM
    Prometheus721
  4. Jan 16, 2014 at 2:53 PM
    la0d0g
    running for the hills
    For crawling not hauling
  5. Jan 17, 2014 at 12:55 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Welcome to TW :wave:
  6. Jan 19, 2014 at 9:23 PM
    Prometheus721
  7. Jan 19, 2014 at 9:24 PM
    Prometheus721
  8. Jan 19, 2014 at 9:25 PM
    madtrucker
    madtrucker Active Member
    Duncan
    Tucson,Az
    08 Red
    trd s/c, Volant cai, trd ss
    Welcome to TW!
