noob LED Turn signal help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YodasYota, Oct 28, 2013.
  1. Oct 28, 2013 at 7:55 PM
    YodasYota
    YodasYota [OP] I'm here for the chicks.
    Yoda
    Orange County CA/the Dagobah system
    White 2005 2.7L
    aFe pro dry s drop in, secondary air filter delete, "Black Box" mod, debadged, tinted windows, 300mm Broadway rear view mirror, LED brake lights, side markers, rear turn signals, plate lights, and interior lights. Flowmaster cat back exhaust, a cracked tail light that I fixed with some tape, all black grille, 15” Raceline 401B wheels, Goodyear 235/75/15 All Terrain Tires
    :confused:I just put turn signal LED's in my 05 2.7l taco. I put the rear ones in first and tested them. But when I put the front ones in and tested them none of them work (front and rear). Does anyone know how I can fix this. I don't have resistors but figured you only need them to stop the hyper flashing.:confused:
  2. Oct 28, 2013 at 8:11 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    check your fuse, it is possible they blew them
  3. Oct 28, 2013 at 8:13 PM
    nammer
    Nam
    Bradenton, Florida
  4. Oct 28, 2013 at 9:29 PM
    YodasYota
    Yoda
    White 2005 2.7L
    so if it is the fuse and I replace it, will it go out right away again?:confused:
  5. Oct 28, 2013 at 9:32 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    No when you replace fuse flip bulb over in the socket should work i did it once or twice.
  6. Oct 28, 2013 at 9:37 PM
    nammer
    Nam
    Bradenton, Florida
    yep it'll blow again, but that would explain why it's not working at all, if it's the fuse, u can try flipping it over like he suggested ^^, but i had to clip the inner wires on the bulb
  7. Oct 28, 2013 at 10:18 PM
    YodasYota
    Yoda
    White 2005 2.7L
    So replace the fuse and flip all four bulbs? The fuse box located right behind the little ash tray on the left correct?
  8. Oct 28, 2013 at 10:31 PM
    nammer
    Nam
    Bradenton, Florida
    yea i can't remember if it's in that one, or the fuse box on the driver's side near the battery, but they'll be labeled too, gl
  9. Oct 29, 2013 at 12:16 AM
    YodasYota
    Yoda
    White 2005 2.7L
    thanks again. hope im not asking to many questions.:eek:
  10. Oct 29, 2013 at 4:10 AM
    nammer
    Nam
    Bradenton, Florida
    not at all, i had to ask tons of q's too, only way to learn, or to be a genius :)
  11. Oct 29, 2013 at 12:30 PM
    YodasYota
    Yoda
    White 2005 2.7L
    I don't think I'm doing this right. I put a new fuse in rotated the front signals and it blew again. What am I doing wrong??
  12. Oct 29, 2013 at 12:32 PM
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    You could have the incorrect bulbs for that socket? or a larger fuse needs to put in but I was told putting a higher amp fuse is bad..
  13. Oct 29, 2013 at 12:32 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Could he need resistors?
  14. Oct 29, 2013 at 12:33 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    When you put just the 2 LEDs in the rear you still had enough resistance for the flasher module to work. This setup should have flashed faster.
    When you put all 4 LEDs in there wasn't enough resistance for the flasher module to work.
    Changing from Incandescent to LED will not blow fuses. Get the resistors for the LEDs or get the LED flasher module.
  15. Oct 29, 2013 at 12:36 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    DO NOT put in a larger fuse. The wiring can only handle some much Amperage. Also LEDs use less Amperage so the fuse is fine.
  16. Oct 29, 2013 at 12:40 PM
    tacodane
    Dane
    Well that's good to know.
  17. Oct 29, 2013 at 12:45 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    2005-2013 Toyota Tacoma LED Turn Signal Flasher
  18. Oct 29, 2013 at 12:48 PM
    BamaToy1997
    Bill
    Navarre, FL
    The first thing to be sure of, which I am willing to bet happened, is you need the correct FRONT turn signal LEDs. They are not the same as the rear. The fronts are 3157CK, and the rear are standard 3157. The difference in the front is that the socket is wired differently than a standard 3157 socket. The ground is on a different terminal. This would explain the blown fuse.
  19. Oct 29, 2013 at 12:50 PM
    tacodane
    Dane
    I was just about to get to that. autolumination.com has ck led bulbs you can use
  20. Oct 29, 2013 at 1:46 PM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    Not sure if this would be the blown fuse problem but when I changed mine. I removed the flasher and moded it directly with the resistors there. I changed the front and rear turn signals to LEDs and tried them. The fronts worked fine but the rears stayed on. Found out I had to change the corners to LEDs as well. No problems after that.
