NooB Lift question
Discussion in '1st Gen. Tacomas (1995-2004)' started by CrackaBruski, Dec 16, 2011.
  1. Dec 16, 2011 at 5:29 AM
    CrackaBruski
    CrackaBruski [OP] Member
    Corey
    canada,NS
    2004 tacoma 4x4 TRD
    Hey I am new to the truck world, I have always had lowered VW's. I have a 2004 tacoma TRD ext.cab. I am looking to go with 15x8 with 33/12.50R15's. I am wanting to know what would be the best way to lift the truck and how much to lift to fit the tires?
    I was looking at spacers and blocks. I just dont want to buy a kit that is to small and the tires not fit. Any input would be wicked guys thanks!!
  2. Dec 16, 2011 at 6:28 AM
    Hot Tamale
    Hot Tamale Well-Known Member
    Pat
    Henderson, NV
    2012 Access Cab 4x2
    Can't answer your question but wanted to welcome you to TW! :wave:
  3. Dec 16, 2011 at 6:30 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  4. Dec 17, 2011 at 5:04 AM
    CrackaBruski
    Corey
    canada,NS
    2004 tacoma 4x4 TRD
    THANKS!
    SO would 2 1/2 inch be enough it fit 33" tires?
  5. Dec 17, 2011 at 5:30 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    There are a lot of variables here. But I'd like to note for 33x12.50s a better rim would be 15x10
    I can't really tell you what to do, but to put 33x12.50s on my truck is still an ongoing process. They are big tires no doubt.
    Before my ARB came I was running 5100s all around, with OME 882 coils in front and a Dakar leaf pack in back. I'd save up and go with better coils and leaf pack AAL (add a leaf) versus blocks and spacers. The backspacing I run is 4". I had to trim a lot off the lower portion of the stock bumper and hammer down the pinch welds in the front wheel wells to clear the front wheels when turned near 90% max. You'll need a longer brake line in back.
    You may also need new UCAs for the front and also may eventually want to regear. I haven't yet, but its on my wish list.
    My tires stuck out quite a bit, so I went with the Bushwhacker cutout fender flares.
    I'd say 2 1/2" maybe with a ALOT of trimming or 2 3/4" to 3" may be better.
    I'm no expert, just have my own experience....
  6. Dec 17, 2011 at 5:46 AM
    wannatoy570
    wannatoy570 Well-Known Member
    Dave
    Lock Haven, PA
    05 Toyota Tacoma SR5
    Do it right the first time. You wont be happy with a spacer and block lift after awhile. Even though you will spend a little more its worth it. Just my two sense. For example this ome lift here will give you an awesome ride and 3in of lift which will be fine for the tires you want to get.
  7. Dec 17, 2011 at 8:16 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    First of al 0" of lift or 3" of lift on the control arm suspension will not matter for tire fitment.
    Don't get spacers or a block... we aren't chevy trucks.
  8. Dec 17, 2011 at 8:58 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    everyone on here will steer you far, far away from spacers and blocks. They make the truck ride like crap and its harmful to your suspension components.
    Bilstein 5100's/Eibach coils, and an AAL is the "budget good lift" known well on here. That will get you 3'' of lift and you can fit 33's.
  9. Dec 17, 2011 at 9:01 AM
    JstreetS
    JstreetS Well-Known Member
    Jay
    DFW, TX
    09 TRD Sport DCLB
    -6" Procomp -18" Method Race Rims -285/70R18 (34.1x11.5) Toyo MTs -TRD CAT Exhaust -Trifecta Tonneau
    Go all out - just get a 6" Drop Bracket :)
  10. Dec 17, 2011 at 11:35 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    If you haven't done so, OP, spend some time reading the Suspension Lift Info and Tacoma Lift FAQ/Guide Stickies. LOTS of good info...
    When you're ready to buy, DSM, , and offer competitive pricing on great (cost-effective) products from manufacturers like Bilstein and OME.
