Noob Question #13: Will they fit?
Discussion in 'Wheels & Tires' started by 28ØØ3, Feb 26, 2009.
  1. Feb 26, 2009 at 7:16 PM
    28ØØ3
    28ØØ3 [OP] Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
  2. Feb 26, 2009 at 7:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    With no lift, you will rub.
  3. Feb 26, 2009 at 7:27 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    w/ no lift on an 18 u'd need like a 265/65/18 or 265/70/17 equivalent....chris knows best!
  4. Feb 26, 2009 at 8:04 PM
    jhodge83
    SC
    17 XLT Sport
    sport rim is a 5.5" BS, but u cant run a 285 on it w/o rubbing the UCA's
  5. Feb 27, 2009 at 5:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When you move the wheel out (different back spaceing), it increases the radius of the wheel travels. Pushing it out a little bit, and fitting 285's on a non lifted truck will cause the tire to hit the front and rear of the fender.
  6. Feb 27, 2009 at 1:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. Im just guessing........I have been around these trucks for quite some time. I wont tell anyone not to do something if I dont have first hand experiance with doing it. And its not that weird that it wont work. The tires are only 4 tenths of an inch smaller in diameter, but they are wider. Lower BS moves the wheel out further from the suspension, BUT, it increases the arc in which the tire travels when turning, thus causeing it to hit your fenders. If you run less BS, as the tire is wider than stock, it will hit the UCA. FWIW, I dont post on here saying not to do someting just for giggles. Im trying to help, and let you know WHY it wont work. Please be my gust to give it a try, and see for your self. :)
  7. Feb 27, 2009 at 2:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I understand. And no offense is taken. :) I have been wrong many times in the past, but I have seen many tires being tried on these vehicles and have a good idea what works and what wont, and why. I dont want to sound like I dont appreciate questions, when in fact, I do. My Internet Text Translator has been malfunctioning, and I thought you may have not understood why I , and Jhodge were saying they wouldnt fit. And I may have gotten a little snappy. :eek:
  8. Feb 27, 2009 at 9:19 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    So basically if I want a 285 tire I need UCA arms, a spacer (or C/O to lift), and most likely a heatgun and removal of mudflaps.
    Son of a .....
  9. Feb 28, 2009 at 4:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, in a nutt shell. A small lift, and different BS wheels will help.
  10. Feb 28, 2009 at 6:35 AM
    drifter379
    drifter379 CenTex Honky
    Texas
    06 Tacoma SR5 Prerunner
    Secondary Air filter mod,Removed running boards,AFE Pro dry filter,sirius satelite radio,relocated horns,sockmonkey decal,EZ change drain plug,color matched grille,grille craft mx, BHLM, Fog light mod, Hellas behind the grille
    yeah what he said.
  11. Feb 28, 2009 at 8:32 AM
    jhodge83
    SC
    17 XLT Sport
    i'd say minimum of 2.5" w/ the right BS wheels....
  12. Feb 28, 2009 at 9:02 AM
    BenJammn5
    BenJammn5 RN
    San Jose
    How about a wheel w/ 4.75 BS? Is it the higher the number the better chance? hmm
    I know, the bolt pattern for the Taco is 6x5.5 w/ 4.5BS
  13. Feb 28, 2009 at 12:19 PM
    jhodge83
    SC
    17 XLT Sport
    bolt pattern IS 6x5.5, but the BS is wheel dependent...not a toyota standard. the sport rims are 5.5 BS, but the OR rims have a smaller BS...like 5 or so...the less BS, the farther they will stick out and be away from the UCA's
  14. Feb 28, 2009 at 3:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Sprot and Off road have the same BS. :)
  15. Feb 28, 2009 at 3:17 PM
    jhodge83
    SC
    17 XLT Sport
    ok...well there ya go...i thought they were diff
  16. Feb 28, 2009 at 3:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There are rumors that the FJ wheels are different, but I cant confirm that one. My neigbor has an FL, and I measured thm to be 5.5 also.
  17. Mar 1, 2009 at 9:08 AM
    BenJammn5
    BenJammn5 RN
    San Jose
    Thanks a lot jhodge. You guys are awesome; so a wheel w/ 4.75 BS wouldn't be a great idea cause it would put it closer to the UCA, that is to say if I wanted a 285 tire. This sucks haha... guess I'll have to look at the pro comp 16" wheel w/ 4.5 BS. The 17" comes in 4.75
  18. Mar 1, 2009 at 9:11 AM
    jhodge83
    SC
    17 XLT Sport
    u miht be able to sneak them by. u're already pulling the rim out by .75" from stock. i'd see if u can get them from a place and try them on before you take off. see if they'll mount some to the front and get in and do some full lock turns and see if its just rubbing plastic in the fenders or actually touching UCA's, etc
  19. Mar 1, 2009 at 9:21 AM
    BenJammn5
    BenJammn5 RN
    San Jose
    my thoughts exactly. I believe discount tire would let me do this.
