Noob question. 2013 OEM Radio quit working? Repalcement?
Discussion in 'Audio & Video' started by Toyadk57, Dec 30, 2021.
  1. Dec 30, 2021 at 12:27 PM
    Toyadk57
    Toyadk57 [OP] New Member
    2013 Tacoma 4x4
    Sorry, new to this forum. Apologize if this topic has been covered before. Tried searching site, but I am not very tech savvy.
    Maybe a simple answer to this.
    Original radio quit picking up most stations, only picks up local ones that are close by and even those tend to fade in and out.
    Called Toyota dealer asked about getting a replacement OEM( NO Nav system, just radio and CD player) and was told it was over $3000. WTF?
    Looked on ebay, etc and can find a used replacement OEM for about $200 to $300. Same model as confirmed by the #s on the face plate of the radio.
    My real concern is that if I get a used radio will it have to be reprogrammed or something to make it work? Has anyone done this? How big of a job is it. You tubed it and just the physical replacement doesn't look to bad.
    Suggestions? Comments? Other Threads? Thanks for any help.
  2. Dec 30, 2021 at 12:34 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Try unplugging the antenna clean the contacts and plug it back in.
    Suggest buyin the new radio from somewhere that does installation.
    ZMan2k2 likes this.
  3. Dec 30, 2021 at 2:51 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5
    Agree with rnish. If you’re stuck on an OEM unit, it is possible to DIY, I’ve not heard that the factory radios need reprogramming. An aftermarket unit would no doubt provide better functionality and sound however.
  4. Jan 6, 2022 at 10:39 PM
    fizik
    fizik Accidental Offroader
    Minnesota
    '13 DCSB SR5, '10 DCSB TRD OffRoad (deceased)
    I too would also suggest checking the antenna connection. You also may have a break in the antenna wire, most likely at the antenna mount. As far as a new HU goes, a factory HU is gonna cost you an arm and a leg installed. I saw a used one on eBay selling for ~$350 (total rip off IMO). I just replaced the stock HU in my 2013 with this https://www.joyingauto.com/joying-8...r-upgrade-system-support-hands-free-call.html and it was easy to install. However, they don't provide a lot of instruction, but there are plenty of install videos on youtube. It comes with a harness that matches all your stock connectors, and a fascia specifically for the Tacoma, so there is no wire splicing and nothing extra to buy (well, almost, you'll need one of these https://www.amazon.com/gp/product/B00F0YJ49O?ie=UTF8 if you want to connect to the stock USB port). See this thread if interested: https://www.tacomaworld.com/threads/2nd-gen-joying-head-unit-thread.706997/
    If you want it professionally installed, a pro can do it in under an hour (probably closer to 15 minutes).
    Have to say, I like mine so far. Even works with the steering wheel controls.
  5. Jan 6, 2022 at 11:01 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    id get a apple carplay touchscreen if i was gonna do it, but i understand oem needs.
