noob question about 4wd and 2wd lifting
Discussion in '5 Lug' started by mcleod90, Nov 28, 2010.
  1. Nov 30, 2010 at 5:37 PM
    mcleod90
    mcleod90 [OP] 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    i might as well just pm you with all my questions. thanks for all the help so far.
    15 is the height of the rim and 6 is the width?
    so once you get your new rims you are going to have to get new tires to?
  2. Dec 1, 2010 at 6:45 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Yes 15 is height and 6 is width.
    Not necessarily. Ideal for the 5lugger are 15x8 rims with 4.5" or 4" of backspacing, you can mount stock tires on those, might look little funny, but its doable... I'd suggest lift first, than tires, than rims. Ideal you would want to get rims & tires at the same time.
  3. Dec 1, 2010 at 7:11 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    not always. going from a higher gear (low number) to lower gear (higher number) could take load off the engine increase your MPG. example. My 87 4runner with its 22re and 4.10 gears w/ 33s made pretty crappy mpg, and regeared to 5.29 w/ 33s you almost never have any foot pressure on the gas. yes more RPM but less load. I used a GPS to track the miles i went and i ended up with 19mpg (all highway)
  4. Dec 1, 2010 at 7:14 AM
    05RedTaco
    Tony
    Scottsdale
    That's good to know :thumbsup:
  5. Dec 1, 2010 at 9:36 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Thanks! (+1 rep)
    If you ask any of the 6 luggers, they would not recommend spacers for a lift. The front suspension on the 6 lug and the 5 lug are completely different, from what I've seen, the 5 lugs don't have a spindle. IMO, spacers on the 5 lug does not really effect the quality of the ride. You can run OEM struts with the spacer.
    As for tires, they do effect the height of the truck. If you don't like loud tires, you can go with a highway thread. You can adjust the PSI in the tire to make the ride a bit smoother.
    I get between 19.5/21 MPG (in town/highway), just depends on what I have in the bed of the truck. I currently have a camper on my truck. It still does great on gas, I just need to regear my truck back to 'factory specs'.
    :cool: (+1 rep)
    My favorite 6 lugger, reg cab, 4x4, super white truck is Drew02a's truck:
    Great info for re-gearing when you increase the tire size.
