Noob question about suspension lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ratliffusmc, Jul 22, 2014.
  1. Jul 22, 2014 at 3:59 PM
    Ratliffusmc
    Ratliffusmc [OP] New Member
    Va beach
    Truck Norris
    I recently bought a 14 Tacoma. My first Toyota, I am very pleased. I'm looking to install a lift, a 2.5 should fit my needs. I've leaning towards the Pro Comp kits.
    Here's my question....
    A few guys at work mentioned that I should stay away from kits that don't come with upper control arms. The arms are needed to keep the cv joints from premature wear.
    What kits should I get? I want a reliable and built well lift kit.
    Any guidance is greatly appreciated.
    Curt
  2. Jul 22, 2014 at 4:02 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Welcome to TW.
    Procomp kits tend to ride harsh. As for CV joint UCAs are unrelated.
    EDIT:
    UCA's help with the alignment. You should be able to get an alignment with a 2.5 inch lift and stock uca's. If you do a 3 inch lift there is a good chance you will need them for a correct alignment
  3. Jul 22, 2014 at 4:04 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    5100's set at 1.75 with stock coils, 2in wheelers single AAL with 5100's or (Old Man Emu N182's or nitrocharger sports if you want some more travel)
    I love mine, personally its how the taco should of come from the factory, and i keep forward rake.... i hate a level truck.
  4. Jul 22, 2014 at 4:05 PM
    StealthTaco
    StealthTaco www.ecgfabrication.com
    Alec
    NC
    05 Black Tacoma TRD Sport 6-speed
    The new upper control arms are to help with your alignment after a 3" lift. Nothing to do with the CVs.
    As far as 3" lifts go, pretty much everyone will recommend OME.
  5. Jul 22, 2014 at 4:05 PM
    Mademan925
    Nick
    Discovery Bay, CA
  6. Jul 22, 2014 at 4:16 PM
    Ratliffusmc
    Va beach
    Truck Norris
    Thanks for the info guys! A follow up question... Would installing a lift cause premature wear on the cv's?
  7. Jul 22, 2014 at 4:24 PM
    BAMS
    BAMS Well-Known Member
    Ray
    New Hampshire
    2011 TX TRD Access
  8. Jul 22, 2014 at 4:27 PM
    FatTony415
    FatTony415 Well-Known Member
    Tony
    San Francisco, CA
    '20 DCSB 4x4 TRD Off Road
    Stock for now
  9. Jul 22, 2014 at 4:44 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    ^x2 on the discount.
    I have this kit
    http://toyteclifts.3dcartstores.com/3-lift-kit-with-Bilstein-5100-Height-Adj-Coilovers_p_364.html
    And I couldn't be happier. The only time it is really rough is on washboarded roads.
  10. Jul 22, 2014 at 4:50 PM
    Large
    Large Red
    OME front to back. If you wheel it you shouldn't worry about parts failing, that's part of the journey.
