noob question
Discussion in 'ToyTec Lifts' started by utmck, Dec 19, 2010.
  1. Dec 19, 2010 at 9:39 AM
    utmck
    utmck [OP] Active Member
    2006 DC TRD Sport 4x4, non TSB, no wheeling - steet only and will be pulling a trailer
    1. If I go AAL, can I expect it to help with payload sag?
    2. How much will it increase the height of the back of my truck?
    3. How much would I need to increase to the front to make it level?
  2. Dec 21, 2010 at 2:15 PM
    Surfinpig
    Surfinpig Well-Known Member
    Eric
    Philadelphia, PA
    10 2.7 4x4 SR5
    Avid Offroad light bar, trd skid plate, are cap, billy 5100's
    I’m researching lifts and want to go a little bigger but also tow and 95% on road. I’m thinking 5100’s and an aal should do the trick. I am tossing up coil over’s but just think 5100’s alone. Oh 5100’s and aal should keep it close to stock level and not kill fuel mileage.
  3. Dec 22, 2010 at 7:03 AM
    utmck
    Would an AAL add any height to the back of my truck?
  4. Dec 22, 2010 at 7:12 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Yes, common AAL sizes are 1.5" and 2".
  5. Dec 23, 2010 at 11:11 PM
    utmck
    So if I went with a 2" AAL, how much lift would I need in the front to level the truck? Also, would 285's fit (remember no wheeling)?
  6. Jul 10, 2011 at 9:39 PM
    mountainman94
    mountainman94 awwwwww yeeeeeeeeahhhhh
    Cory
    A Place of Higher Learning
    '98 TRD SR5
    5100's/Eibach coils; 2 inch toytech AAL, Black Pacer 15x8 wheels, 32x11.5 BFG AT K/Os
  7. Jul 10, 2011 at 9:46 PM
    Ez2typethis
    Ez2typethis Well-Known Member
    Santa Maria, CA
    10 TRD sport 4x4 TRD S/C, TRD Cat back
    My 2010 4x4 TRD sport: Bilstein 5100's in the front set at 1.5" to level, TRD Supercharger, TRD Cat back, TRS retrofit, Satoshi grill, Redlinetuning hood struts, Socked ***SOLD***
    Get the TSB done and buy billstien 5100's for the front and get them installed at 1.75" and you'll be pretty lvl... That is how i am set up and i pull small trailers often with plans for a 20' travel trailer soon.
    Just my opinion...
    Good luck!
  8. Jul 11, 2011 at 12:36 PM
    nmhs
    nmhs Member
    What are the pros and cons of setting the shocks at 2.5?
  9. Jul 12, 2011 at 11:02 AM
    Ez2typethis
    Santa Maria, CA
    Pros: added ride height for slightly larger tires. 5100 series offer better valving than stock so ride quality will definitely be improved.
    Cons: you will probably want to get more than just the rear tsb done to be level or you will have that baja'd look. Must adjust headlights down a bit. No other adverse affects that I know of!
  10. Aug 14, 2011 at 10:25 AM
    Skidmarc
    Skidmarc Active Member
    Marc
    Atlantic Canada
    4WD I4
    Another noob here. I would be looking for an estetic 1"-2" lift max. With such a small lift, would I shorten the life of any front suspension parts? What would be the better way to go. Thanks....
