Noob spacer question
Discussion in 'Suspension' started by jester156, Nov 4, 2009.
  1. Nov 4, 2009 at 4:54 AM
    jester156
    jester156 [OP] Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    I plan on installing my 5100's with eibach's this weekend with the driver side spacer. I have searched everywhere for the location of the spacer. Do I install the coils on the shock, secure the nut then put the spacer on top or does it go on the coil first, then the cap and nut?
  2. Nov 4, 2009 at 5:15 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    spacer on top of everything. then coilover. the spacer will go between the coilover and the strut tower/perch/where it mounts to the truck
    EDIT: that is if its a top plate spacer... if not then it will go inside the coilover,on top of the coil
  3. Nov 4, 2009 at 5:44 AM
    jester156
    Cumberland, RI
    its the 1/4" spacer from Toytech.
  4. Nov 4, 2009 at 5:52 AM
    jester156
    Cumberland, RI
    much appreciated all.
  5. Nov 4, 2009 at 1:35 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    post pics when your done. i just order the same setup.
