Noob towing question
Discussion in 'Towing' started by SR5Taco07, Aug 5, 2013.
  1. Aug 5, 2013 at 4:20 PM
    SR5Taco07
    SR5Taco07 [OP] Member
    07 ST5 double cab off road
    First off I'm new to the site. Long time Toyota guy but just bought my first Tacoma.
    I read other threads on this but wanted to make sure before I go out a tow over 3500lbs. I read on other threads if you have a small radiator looking thing in front of the actual radiator then you have the towing package.
    In the picture, is this the small radiator looking thing you guys are talking about? I bought the truck used and it has no owners manual so I can't see any towing info. It did come with a 7pin to 4pin adapter and there is one bolt on each side mounted to the bumper.
    Thanks and sorry for the repost but just wanna make sure.
  2. Aug 5, 2013 at 4:23 PM
    Gaunt596
    Gaunt596 Resident Otaku
    Matthew
    Central Maryland
    07 Double Cab Long Bed V6 SR5 4x4 "Morrighan"
    Rain visors, Fog Light Anytime, Uniden 505xl CB Radio and 5 foot Firestick antenna, RTMR Fuse box, Mobtown Offroad Recovery Bar with 2" Receiver Tube, OME standard kit
    You need to check, you should have a transmission cooler(that small radiator) and a pigtail with plug for a brake controller. the pigtail looks like a white plastic plug with a bunch of colored wires with stripped ends on it.
  3. Aug 5, 2013 at 4:28 PM
    SR5Taco07
    I took that picture, where is this pigtail located?
  4. Aug 5, 2013 at 4:32 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    The "pigtail" should be in the glove box. If not check the center console, behind the rear seats, and under the rear seats (if double cab). This pigtail allows you to use a trailer brake controller easily. The loose ends connect to the loose ends that the controller has and plugs into the plug behind the drivers lower kick panel. Trailer brake controllers are very helpful when towing big and loaded trailers that have electric brakes.
  5. Aug 5, 2013 at 4:35 PM
    That Dude Tim
    Elyria, OH
    If you have the 7pin in the back, a hitch, and that extra cooler for the trans then your truck has the package. The pigtail is something that could have been taken out of the truck if it wasn't hooked up.
  6. Aug 5, 2013 at 4:37 PM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    Yep, that's a tranny cooler you have pictured. My pigtail was stuffed under the dash above the steering column.
  7. Aug 5, 2013 at 4:45 PM
    SR5Taco07
    I couldn't locate a pigtail. I looked in the storage are by the fuses, glove box and center console. Noticed this fan was pink. I remember reading something about that also.
  8. Aug 5, 2013 at 4:54 PM
    SR5Taco07
    I think I found my pigtail, lol only problem is that it's not hooked to anything.
  9. Aug 5, 2013 at 4:56 PM
    Germ
    Arizona
    2013 TRD OR DCSB
    Refer to my previous post. Should be a harness located way up in the steering column. Mine was a pain to reach.
  10. Aug 5, 2013 at 4:58 PM
    SR5Taco07
    I found it, it was in my glove box never hooked up. I took a pic
  11. Aug 5, 2013 at 5:03 PM
    Germ
    Arizona
    2013 TRD OR DCSB
    Right, what I'm saying is you have to connect it.
  12. Aug 5, 2013 at 5:06 PM
    That Dude Tim
    Elyria, OH
    Ok good. You'll still need a trailer brake controller to utilize the trailer brakes. That pigtail hooks up to the pigtail the brake controller comes with. Then you hook it up to the plug behind the lower front kick panel on the drivers side. There is an empty plug in there. If you don't have a controller then anything plugged into the 7pin in the back only stops from the truck brakes and the lights might work too.
  13. Aug 5, 2013 at 5:06 PM
    SR5Taco07
    Ok thanks, I'm not hauling anything soon but it's nice knowing. Guess with all the findings I do have the tow package. Thanks again.
  14. Sep 18, 2013 at 11:01 AM
    zakattak
    zakattak Well-Known Member
    Zak
    Jacksonville, FL
    2015 TRD Sport Double Cab Long Bed
    ok so i have an 05 prerunner double cab v6 4l...and im wondering what all i gota do to tow 5k lbs....theres a reese hitch in the back bolted to the frame...and a pink mount on my fan ...what does that mean? i went out and bought a brake controller and the neccessary harness and mounting stuff to go form the 4 pin to the 7 pin but still need to install it, also looking for a trans cooler to haul easier on my transmission. anything im missing here? that isnt a towing package right if i need a trans cooler? and that reese hitch is ok for 5K pounds? dumb question but i called the toyota dealer and asked this and he says sure get a cooler, it could help, and even though the reese hitch says max load 3500lbs/tongue 350lb it will haul the 14x7 double axel trailer just fine....<.<
