Noob Towing Question
Discussion in 'Towing' started by Roll_Terps, Oct 7, 2021.
  1. Oct 7, 2021 at 2:41 PM
    Roll_Terps
    Roll_Terps [OP] Well-Known Member
    Maryland
    2017 SR DCSB White
    My towing experience is limited to moving light towers and message boards around a construction site, so I came to double check my setup and idea.
    Truck: Tacoma SR V6 4x4 with tow package
    Mods: 265/70/17 AT tires (was 245/75/16 from factory)
    GVWR: 5600#
    Towing Capacity: 6800#
    Hitch MGTW rating: 6000#
    Hitch touge weight carrying: 600#
    Trailer: two-axle Uhaul Auto Transport
    Trailer weight (empty): 2210#
    Trailer max load: 5290#
    Trailer max gross: 7500#
    Cargo: 2010 Volkswagen Beetle
    Cargo weight: ~3400# (most conservative)
    Trip: CT to MD, 280 miles via NJ turnpike and I-95
    So combined cargo and trailer weight is conservatively 5610# which is decently below my capacity of 6800#. Also well below the max rating of the trailer. Vehicle GVWR is also above 80% of trailer gross.
    Just need a gut check/advice on if I'm good or this is one of those 'just because you can, doesn't mean you should' scenarios. Thanks
  2. Oct 8, 2021 at 11:55 AM
    Inbred
    Inbred Well-Known Member
    Phinnius
    2nd generation euphoria
    The data you cite suggests you are within the limits of your towing capabilities. Keep calm and tow on.
  3. Oct 8, 2021 at 11:57 AM
    LSKinetic
    LSKinetic ah beans
    NJ
    2001 Tacoma TRD OR V6 5speed
    your mileage will take a pretty big hit but other than that you'll be fine.
  4. Oct 8, 2021 at 1:37 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    You are within tow capacity but that’s a lot of weight for a Taco. Since it’s a 1 time trip go ahead and make the tow. Go slow, stay below the speed limit on the highway. Keep an extra long length between you and the vehicle in front of you. It will not be an easy or pleasant tow but you can do it. Good luck.
  5. Oct 22, 2021 at 8:27 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    I pull 5,100 all the time. Get a WDH and take your time. Drove 400 miles one way to Bend OR from Spokane, WA. Don't be stupid about it. When you get there you get there.
  6. Oct 28, 2021 at 3:05 PM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    Just take your time. I towed a 94 accord (~2700) on a uhaul transport. If you get up to highway speeds the trucks definitely seem more comfortable at 60. I only went 10 miles probably most being highway. Just take your time and be smart.
  7. Oct 31, 2021 at 4:04 PM
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    does the trailer have surge brakes? Whatever brake system it has be sure it works before you start your tow.
  8. Nov 2, 2021 at 3:34 PM
    AZ Pete
    Arizona
    if you drive conservatively, about 10 mpg. I tow a 18' travel trailer, single axle, 3,500# and can get 13. The TT is lighter than your load, but with more frontal area, thus more wind resistance....be happynwith anything over 10.
